Boost drop @ WOT?
Old Sep 1, 2004 | 04:33 PM
G3NR8's Avatar
Default Boost drop @ WOT?
Is it normal for boost to drop off at WOT?? Mine is set @ 9psi, or .63 bar on my VAFC, and while at WOT I watch the VAFC drop down to about .55-.53. I'm just wondering if this sounds normal, or what would cause it if it is a problem.
Old Sep 1, 2004 | 05:28 PM
93turbo16's Avatar
yea its called the wastegate can't keep up with the boost, and its creeping then it settles down.
Old Sep 1, 2004 | 05:35 PM
G3NR8's Avatar
Default Re: (93turbo16)
so basically the WG is really set lower, but is creeping? I think I understand what your sayin...That would make sense since its a 7psi internal wg. How can I stop it from creeping??
Old Sep 1, 2004 | 07:20 PM
93turbo16's Avatar
Get a better source for your boost controller or if its right to the wastegate, get a better boost source from the manifold, brake booster or something. Sometime this is common with bigger exhaust.
Old Sep 1, 2004 | 07:37 PM
G3NR8's Avatar
Cool...I'll try that. I was just reading some other posts (guess I shoulda searched) and alot of people were talking about the compressor not being powerful enough at higher rpms. Its only a 14b, so I could understand that too....
Old Sep 2, 2004 | 04:32 AM
yaya's Avatar
Default Re: Boost drop @ WOT? (G3NR8)
what about your cams? or the overlap? i think having too big of cam or some fucked up overlap can cause limited boost. but im not sure if that would only happen at wot
Old Sep 2, 2004 | 06:09 AM
93turbo16's Avatar
I don't think that turbo would run out on a d series motor, maybe a b16, but I doubt it.
Old Sep 2, 2004 | 06:18 PM
yaya's Avatar
ooops didnt see the SOHC-T sig
b20vtech
Jan 24, 2008 05:55 PM
Mad Cow
Feb 24, 2005 06:12 AM
B_1_8_hatch
Oct 6, 2003 12:01 AM
dallasyoung
Feb 3, 2003 04:56 PM
