Filter or no Filter on your turbo inlet?
Re: Filter or no Filter on your turbo inlet? (mchuang)
Are you talking about on your compression housing?? If yes. hell yea you need one. what if a rock, leaf, a piece of paper, etc; were to get sucked up in your compression housing.... NO MORE BOOST!!!!
Re: Filter or no Filter on your turbo inlet? (psileepR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psileepR »</TD></TR><TR><TD CLASS="quote">yes and it will actually make more power with one on. </TD></TR></TABLE>
so then y do people put screens on there comp. housing when at the track?
Re: Filter or no Filter on your turbo inlet? (honda9369)
use a filter ... K&N = $30.00 .. Turbo > $500.00 .. get my point.
Go on ebay, buy some cheap cold air intake, chop it up and slap a filter on it
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda9369 »</TD></TR><TR><TD CLASS="quote">
so then y do people put screens on there comp. housing when at the track?</TD></TR></TABLE>
maybe because they cant fit one on there? most people just fab up a velocity stack or something for the track.
fredo broke it down for you though. it doesnt take that large of an object to do enough damage to a turbo to make it useless
i cant explain why, but my friend brett's 1000hp supra made 40 less hp with the filer off the turbo and we did 6 back to back pulls and same out put...put the filter back on and power was up again
Re: Filter or no Filter on your turbo inlet? (david_rg79)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by david_rg79 »</TD></TR><TR><TD CLASS="quote">i cant explain why, but my friend brett's 1000hp supra made 40 less hp with the filer off the turbo and we did 6 back to back pulls and same out put...put the filter back on and power was up again</TD></TR></TABLE>
WoW 1000HP Supra and the guy is worried about 40 horse
i would use the filter, personally i dynoed the car with and without the filter, there were no significant changes in power... with the filter is safer...
OG triple OG
Re: Filter or no Filter on your turbo inlet? (Si[R])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si[R »</TD></TR><TR><TD CLASS="quote">]
WoW 1000HP Supra and the guy is worried about 40 horse</TD></TR></TABLE>
if your goal was 1000whp , and you made 960 , wouldnt you care about the 40 horses?
Re: Filter or no Filter on your turbo inlet? (Hella_JDM)
i was talkin to this dude who had turbo on his car..he said it blew,when he picked the turbo up from the guy that was rebuilding it,he was told the turbo failed due to 2 pebbles...use a filter
Re: Filter or no Filter on your turbo inlet? (bukbukintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bukbukintegra »</TD></TR><TR><TD CLASS="quote">i would use the filter, personally i dynoed the car with and without the filter, there were no significant changes in power... with the filter is safer... </TD></TR></TABLE> i did this also and found the same results, so just run a filter on it
Re: Filter or no Filter on your turbo inlet? (B18C1CYA)
FILTER!!!@! i havent ran my car without a filter AT ALL, first start up after the install the filter was on, no way id run without a filter.
Re: Filter or no Filter on your turbo inlet? (SSBPGSR)
I'm still trying to find a filter that fits I'm thinking about the HKS style, it is VERY short, and might just fit
Re: Filter or no Filter on your turbo inlet? (toolowsol)
Re: Filter or no Filter on your turbo inlet? (USDM 4G VTEC)
what do you guys recommend for a strict drag car. i dont think i am goin to have enough room to put a filter on the housing.
Re: Filter or no Filter on your turbo inlet? (maxspeedhonda)
I run mine with just a screen over the turbo.. But then again this is a track/weekend car.. If I was driving it everyday then I would run a filter on it..
How many people do you see riding around NA without a filter, probably not many..
Re: Filter or no Filter on your turbo inlet? (tgreaves)
I don't run a filter. Just run a screen.
If you're gonna run a filter, find one that is not restrictive because you'll lose power because the filter "chokes" the turbo.
Re: (mildly interesting)
you need to run a good filter like K&N or apexi. ive seen first hand that an off brand filter came apart and ended up sucking into the turbo....chewed up the compressor wheel quite a bit...
Re: (Mase)
I was running with just a screen for a few days, the car was sluggish because it was sucking in all the hot air the fan was pulling from the radiator. I decided to slap the intake back on to see if it made a difference and it was night and day. Keep that in mind when running no filter in a similar setup.
