Pre-install checklist
Old Sep 1, 2004 | 02:42 PM
EFbomb's Avatar
Default Pre-install checklist
Its going down tomorow night ... im installing everytyhing, then running open o2 housing to the muffler shop where they will make the DP and weld up the charge pipes.
I am going to run the "hack" for now, my friend is socketing his p28 this week, and ifs it is sucessful i will be running uberdata by october.
CAR : 1994 Del Sol VTEC(b16a3) - 113k
allready installed:
skunk2 catback
Vafc
boost gauge
vacuum distribution block
Exedy 3 puck stage 2 clutch
exedy 9lb flywheel
dc header
cai - will be used for charge piping
Turbo Install parts:
DropShop log mani (a/c comaptible/have not test fitted)
14b DSM turbo (70k no shaft play)
DSM o2 housing
dsm felpro turbo gasket kit(mani to turbo,o2housing,coolant,oil lines)
OEM honda exhaust manifold gasket
Johny Race Car 4" intercooler - allready fitted and bumper trimmed
DSM 1g bov@pipew/flange
DSM 450cc injectors
OEM honda injector seals
Honda resistor box of f22a
2.25 i/d u bend (turbo to ic charge pipe)
2.5 i/d u bent (after IC charge pipe)
Blue Silicone ebay special Tube (2-2 feet section (2.25 & 2.5for coupplers)
3' -3an stainless feed line w/banjo for 14b
1.5' -3an stainless line for feed to tee
oil line tee
(2)bspt > npt adaptor
OEM oil press unit
OEM oil pan gasket w/ultraflange
1/2" i/d stainless drain
turbotoys 14b oil drain aluminum oil drain flanges
I plan on having the muffler shop make a DP off the o2 housing. Using their gaskets & flanges. 2.5" off o2 housing , mandrel elbow , 2.5" flex section(i provide), 18" - 2.5" id - 4" od resonator to exhaust. weld charge pipes and probably make bend for compressor outlet to intercooler inlet.
Let me know if im missing anything.
thanks in advance - no hack haters please, i know ... i will retard dizzy 2 deg b4 startup
i know i need turbo inlet filter, but im just goning to screen it for startup.
oh yea - what plugs ?
thanks guys and gals
Old Sep 1, 2004 | 04:14 PM
xenocron's Avatar
Default Re: Pre-install checklist (SBD)
http://www.xenocron.com/checklist.htm
That was my checklist...it may be a little out of order now that I know more, but it should give you a couple ideas
Old Sep 1, 2004 | 06:52 PM
EFbomb's Avatar
Default Re: Pre-install checklist (xenocron)
thats a very thorough checklist. thanks. I totally forgot about plugging up my o2 sensor hole on the housing, and having one made in the DP.
b16 turbo plugs anyone ?
want2rally
Feb 1, 2007 12:56 PM
pgmatt
Sep 12, 2005 07:41 PM
teamlegacy
May 5, 2003 06:25 PM
teamlegacy
Apr 30, 2003 10:54 AM
