how much boost can b18b handle stock?
Old 08-29-2004, 04:52 PM
10 psi's Avatar
Default how much boost can b18b handle stock?
I've searched and couldn't find a answer
10 psi is offline
Old 08-29-2004, 05:01 PM
boost fed ls's Avatar
Default Re: how much boost can b18b handle stock? (10 psi)
mine has seen 11psi with no problem.
boost fed ls is offline
nonvtecD's Avatar
what do you qualify as a search, give me a turbo, I'll tell you what psi it can handle. B18 internals can handle 300 hp when well tuned.
nonvtecD is offline
Old 08-29-2004, 05:02 PM
You should be asking how much horsepower the stock block could handle rather than a boost level. From what I have seen, you can make 300hp on the stock motor safely with a good tune. I made 338 on a stock b16a @ 14psi
maxspeedhonda is offline
Old 08-29-2004, 05:03 PM
integlspwr2k's Avatar
Default Re: how much boost can b18b handle stock? (maxspeedhonda)
you can run 12lbs, but get it tuned properly.
integlspwr2k is offline
Old 08-29-2004, 05:07 PM
10 psi's Avatar
Default Re: how much boost can b18b handle stock? (integlspwr2k)
i want to make around 275whp and it still be a daily driver (and im using a T3/T04E turbo)
10 psi is offline
Old 08-29-2004, 06:07 PM
donkiman's Avatar
u should reach 275 with 10 or so psi with that turbo. i saw 290whp on my gsr with 9 psi. As everyone on this forum will tell you.... do not push that much boost without getting it tuned.
donkiman is offline
Old 08-29-2004, 06:09 PM
jdmteg96's Avatar
i would say since it is a daily driver run like 6 or 7 pounds of boost. and slap on a manual boost controller so that you can turn the boost up when you need to...but for a daily driver i would say keep it at 6 or 7 pounds
jdmteg96 is offline
Old 01-27-2018, 03:26 AM
Default Reply
I've got a b16 top end b18 bottom end, mind you yes it is different then what you have but I run 6psi and make 235 to the wheels. Engine could handle a lot more as the engines build.
NicJoudz97 is offline
Old 01-27-2018, 04:23 AM
Autoworks's Avatar
PSI alone means nothing. "T3/T04E" doesnt really tell you anything definite either.
Can you make 275whp on a stock block in good health...yes all day. At what psi...who knows, that varies (and doesn't really matter)
Autoworks is offline
Old 01-27-2018, 04:58 AM
Chance EG's Avatar
This thread is from 2004 lol
The correct answer is 1 million WHP and 2PSI.
Chance EG is offline
Ludeist
10-25-2007 12:26 PM
JDM_Acccord
07-05-2007 03:24 AM
TegraBoy
07-14-2004 12:03 PM
projectTeG
11-07-2003 06:56 PM
Andrew 825SM
10-02-2002 07:39 PM
Quick Reply: how much boost can b18b handle stock?
  • Ask a Question
Question Title:
Description:
