Almost ready.some clearance issues(Tinker come and see =) ) PICS PICS PICS
Well i am 90% ready to finish my setup but i still have some questions about my downpipe and how can i get to do it.
First for references, here is my other build up thread.All my block and motor build is there..
https://honda-tech.com/zerothread?id=860134
I had posted that i had problems with a manifold i got because it was not too A/C friendly..There was barelly 3" of clearance between the Turbo and A/C compressor so i sold that manifold and ordered a MiniMe from LoveFab(Cody).I wanted to do a 3" Downpipe
Well i got my manifold and it is beautifull BUT, when test fitting again it seems that now i even have less clearance than with the old manifold(the quality and prettyness of this manifold makes it a Keeper so thats why i want some feedback as to what to do).
Here are some pictures
Welds on the manifold are preeeeeeeeetty
Manifold, Turbo and Racegate(42mm)
In the car
In the car
Clearance issues:
If you can se in the pics..The space between the turbo and A/C compressor is thight.. I dont think a 3" DP fits..So can i make a 2.5" and Flare it to 3" ?
Under the car!
Under the car!
Re: (fjt)
Intercooler: 31 x 6 x 2.75
I will have to loose my fog lights because the inlet/outlets are barely 1/2" from the fogs..The fogs are just right in the middle so cutting the fogs bracket as others do will not work(with a smaller FMIC it works).
Heres my fancy radiator
Re: (fjt)
go for it with the 2.5-3 inch flare.your turbo probably has a 2.5 exducer bore so i dont think you would lose much at all by sarting off with a 2.5.or you could suffer like me and take out the ac i hate south florida weather,and im sure pr isnt any better
Re: (buckfittyone)
Taking A/C out is not an option je je(i would have ordered the Non AC mani and saved 100 bucks there)..Our winters here are 80degrees weather ..lol
Re: Almost ready.some clearance issues(Tinker come and see =) ) PICS PICS PICS (EM1 MIKE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1 MIKE »</TD></TR><TR><TD CLASS="quote">Looks good, just get rid of the zip ties. </TD></TR></TABLE>
I think the zip ties will get rid of themself once they feel that heat
Re: Almost ready.some clearance issues(Tinker come and see =) ) PICS PICS PICS (redturbocivic)
Lol i should had put a Zip tie Warning on the thread..That was just to test fit... Oviously it will have the right bolts when i install everything
Re: Almost ready.some clearance issues(Tinker come and see =) ) PICS PICS PICS (Tinker219)
you should of had cody make you one with the manifold. then you know it would have been all set.
Landon
Landon
Re: (lanojp1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lanojp1 »</TD></TR><TR><TD CLASS="quote">be careful of that wastegate...ive seen them turn to **** in no time and boost creep like crazy...</TD></TR></TABLE>
that is the Race gate, not the Delta gate.. or have you had personal bad experiance's with the Racegate ??
Re: (Dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic »</TD></TR><TR><TD CLASS="quote">
that is the Race gate, not the Delta gate.. or have you had personal bad experiance's with the Racegate ??</TD></TR></TABLE>
why even bother with those wg's get a tial and if you can afford it turbomuff.
Re: Almost ready.some clearance issues(Tinker come and see =) ) PICS PICS PICS (fjt)
I say your best bet is to try and find a Cast Iron downpipe.A cast downpipe will throw less heat on the compressor than a thin guage pipe and I seen a few that almost come straight down off the turbine....like this Greddy
Re: Almost ready.some clearance issues(Tinker come and see =) ) PICS PICS PICS (RACEPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK »</TD></TR><TR><TD CLASS="quote">
where is the a/c fan ?? or whatever it called....</TD></TR></TABLE>
in those pics both fans where removed..the Wastegate hit the Radiator fan..both fans will be replaced by thin Push fans<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Man »</TD></TR><TR><TD CLASS="quote">I say your best bet is to try and find a Cast Iron downpipe.A cast downpipe will throw less heat on the compressor than a thin guage pipe and I seen a few that almost come straight down off the turbine....like this Greddy
Hmm do you know where i can find one of those?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k »</TD></TR><TR><TD CLASS="quote">
why even bother with those wg's get a tial and if you can afford it turbomuff.</TD></TR></TABLE>
1. this is not a creepy Deltagate..It is a Racegate 42mm so it should do the work.
2. i had to keep it cause i ordered the Manifold and Cody needed to custom fit it,which he did nicelly...I didnt wanted to risk having this gate as a Paper holder on my desk when i spent money on it(it costs 400+ new )..I tried to sell it but with so lil time it was impossible..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 »</TD></TR><TR><TD CLASS="quote">The Ds are next to impossible to go with a full 3". 2.5-3" fits with ease though!</TD></TR></TABLE>
Thanks Cody ill work it out as a 2.5" flared to 3" then.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fjt »</TD></TR><TR><TD CLASS="quote">
.</TD></TR></TABLE>
where can i buy thin push fans?
.</TD></TR></TABLE>
1 Post
Re: Almost ready.some clearance issues(Tinker come and see =) ) PICS PICS PICS (FOrSfEd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd »</TD></TR><TR><TD CLASS="quote">Damn that is a beatiful manifold.</TD></TR></TABLE>
not bad for an 18 year old kid eh? Yep, thats my brothers work! The lil ******* getting penetration a lot more solidly than I am...at least on the first pass
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK »</TD></TR><TR><TD CLASS="quote">where can i buy thin push fans?</TD></TR></TABLE>
Well push fans in general are thin...atleast all ive seen.
I believe almost any autopart store sell them
