Do I need To Overbore or Not?
Old Aug 29, 2004 | 10:18 AM
Ceres's Avatar
Default Do I need To Overbore or Not?
Im doing a engine rebuild because I blew a ring.
Simple Question.
Car = 2000 GS-R Turbo w/ 55k miles
Do I really need the overbore (81.5mm) or just stick with the standard bore. I havent pulled the block out and inspected the sleeve, but motor only have 55k so I don't think the sleeves are fucked up badly
Old Aug 29, 2004 | 02:18 PM
Ceres's Avatar
any answer this please?
Old Aug 29, 2004 | 04:21 PM
14bcoupe's Avatar
Default Re: (Ceres)
most likely you wont need to bore out the sleeves with bad rings,but you ll def need to hone them so when you put on the new rings they ll seal well in the cylinders.
Old Aug 29, 2004 | 04:23 PM
EM1 MIKE's Avatar
Default Re: (14bcoupe)
Hone for sure, no need to bore them.
Old Aug 29, 2004 | 06:41 PM
22psicrx's Avatar
Default Re: Do I need To Overbore or Not? (Ceres)
should over bore for good ring seating. Go .20 over. nothing crazy.
Old Aug 29, 2004 | 07:14 PM
HybridKOOP's Avatar
Default Re: Do I need To Overbore or Not? (22psicrx)
If your fingernail snags ANY of the lines/scratches on the cylinder walls, it's a very good idea to overbore/re-hone.
Old Aug 29, 2004 | 07:42 PM
dunkd's Avatar
best idea would be to take it apart and go to the shop that you are going to have do the machine work... do whatever they tell you to do. most likely you will just need to have it honed.
Old Aug 29, 2004 | 10:00 PM
night's Avatar
Default Re: (dunkd)
ummm... dont do whatever they tell you.
you may the only customer they've seen that week....
Old Aug 29, 2004 | 11:07 PM
Ceres's Avatar
Default Re: (night)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by night &raquo;</TD></TR><TR><TD CLASS="quote">ummm... dont do whatever they tell you.
you may the only customer they've seen that week....</TD></TR></TABLE>
Yeah thats true, generally is overbore for a tighter clearance to get rid of blow-by.
But if I don't overbore it a little does that decrease performance and everything? I just don't want to overbore and find out that it won't fit.
black_ek
Sep 26, 2007 05:29 AM
rdeezy78
Jan 2, 2007 06:50 PM
94tegdude
Feb 15, 2005 10:33 PM
deSigi
Jun 8, 2004 06:50 PM
Chuji
Sep 11, 2003 09:00 PM
