Car hesitation at 4500+ rpm and now it wont start!!!!!!
Well this is the problem with my car.
Everytime i rev up my car past 4500 rpm it starts to bog like its not picking up speed and it hesitates. This was happening for like 2-3 days but today when i came home today i shut it off and tried to start it later on it wouldnt start again.
Engine cranks but wont turn over
I check all the fuses and for any leaks but couldnt fine anything. everything looked fine.
I changed the plugs and also changed the sparks plug wires but no luck
can any one give me any ideas on what to look for next and what the problem could be
here is my set up
95 gsr
T61 turbo
t4 manifold
valvespring and retainers
3 inch downpipe and exhuast
here is my set up
95 gsr
T61 turbo
t4 manifold
Re: Car hesitation at 4500+ rpm and now it wont start!!!!!! (b18c195)
any smoke or fluid leaks? do a compression test, and check to see if you are getting fuel and spark....
Re: Car hesitation at 4500+ rpm and now it wont start!!!!!! (Mase)
I say the same. Were you missing before the car shut off the last time? Were you failing to hit the VTEC crossover?
OrangeBoost
06-30-2006 09:15 AM
