need a chip for my ecu ASAP PLEASE HELP
Old Aug 28, 2004 | 11:51 PM
desert eagle's Avatar
Default need a chip for my ecu ASAP PLEASE HELP
does anybody know of a reputable ecu chip burner for obd0 ecus:
setup: ls/vtec stock block, pnp b16 head, ported and port match sk2 im, t3/t4 turbnitcis turbo, 3 bar map, 440 injectors, 255 hi flow walbro pump, aem fuel rail, vortech fmu, fpr, 2.5 inch dp. 12lbs boost cut.
if somebody could burn me a chip for that please let me know asap.
thanks
Old Aug 29, 2004 | 05:21 AM
b18cls1's Avatar
Default Re: need a chip for my ecu ASAP PLEASE HELP (LsVteC81)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVteC81 &raquo;</TD></TR><TR><TD CLASS="quote"> 440 injectors, 255 hi flow walbro pump, aem fuel rail, vortech fmuif somebody could burn me a chip for that please let me know asap.
thanks</TD></TR></TABLE>
first problem is 440 with a fmu under boost there will be way too much fuel with the fmu and the injectore,, pick one or the other
Old Aug 29, 2004 | 06:38 AM
Default Re: need a chip for my ecu ASAP PLEASE HELP (b18cls1)
yeah i understand that. the stock injectors are in there right now. when i find someone to burn me a chip im gonna remove the fmu.
Old Aug 29, 2004 | 07:00 AM
Joseph Davis's Avatar
Nobody can burn a chip that's going to cover your setup perfectly, requires custom tuenaring.
Old Aug 29, 2004 | 09:12 AM
b18cls1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVteC81 &raquo;</TD></TR><TR><TD CLASS="quote">yeah i understand that. the stock injectors are in there right now. when i find someone to burn me a chip im gonna remove the fmu.</TD></TR></TABLE>
email me and ill help
Old Aug 29, 2004 | 09:21 AM
toolowsol's Avatar
anybody can make you a chip in turboedit, but you have to understand it will require tuning to run properly and safely.
kauai96
May 27, 2009 06:59 PM
motorhead_guy
Jun 17, 2006 08:49 AM
spoon95eg
Dec 19, 2005 06:15 PM
b18c1srfun
Nov 23, 2005 12:18 PM
NuRv
Aug 18, 2004 06:29 PM
