B16a dyno results
Old Aug 28, 2004 | 10:19 PM
Boosted Chemist's Avatar
Default B16a dyno results
B16a1, portflow springs, cometic (.058 i think) headgasket, innovative T3/T4 57 trim .63 a/r 10.5 psi, inline pro mani, tial 38mm + bov, 2 1/2" charge pipe, 3" turbo back, dsm 440s, turbo edit chipped pm6 with a homemade base map, Fine tuned (max of plus or minus 5%) with a vafc.
It was 80 in the shop and kinda humid out.
my first pull was 185 hp/145 torq lol the best we got but didnt print was 262
Old Aug 28, 2004 | 10:21 PM
Default Re: B16a dyno results (Mad Chemist)
also i beat the **** out of my car last night, tonight the timing belt all off a sudden ripped to shreads, any ideas what happened? im guessing something fell in the cam gear ?
Old Aug 28, 2004 | 10:27 PM
nocom's Avatar
Great numbers! Are your cam gears exposed?
Old Aug 28, 2004 | 10:29 PM
brixity's Avatar
yeah i've seen people drop things in their timing belt cover and it heads straight for the back of the crank pulley inside the belt cover. you should make sure that the dyno place didn't do it. they could have possibly dropped something in there if they were last ones working on ur car. good luck
Reggie
Old Aug 28, 2004 | 10:32 PM
RA166E's Avatar
Those are nice numbers. Looking at my sheet I made 288.6HP/217.7 at 14psi no bottle.
I lucked out on temps it was only in the low 70's.
Old Aug 28, 2004 | 10:49 PM
Default Re: B16a dyno results (brixity)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brixity &raquo;</TD></TR><TR><TD CLASS="quote">yeah i've seen people drop things in their timing belt cover and it heads straight for the back of the crank pulley inside the belt cover. you should make sure that the dyno place didn't do it. they could have possibly dropped something in there if they were last ones working on ur car. good luck
Reggie</TD></TR></TABLE>
my cam gears are exposed and we were adjusting them, maybe something fell in the valve cover. I doubt its the shops fault i drove 50 ish miles(home work home voer a days period) , then this happened, maybe a rock or some thing stupid becuase the belt is fucked up on the back side (smooth side) and the belt remained on, the car died because the exhaust cam jumped 75 degrees. When i took off the belt it was only 1/2- 1/4 thick all the way around.
What do u think (in respect to the curve) that if i turned up my rev limiter to 9k (gotta love portflows ) i could gain a higher top end hp and be still safe.
Old Aug 29, 2004 | 12:22 AM
MrEG6er21
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mad Chemist &raquo;</TD></TR><TR><TD CLASS="quote">B16a1, portflow springs, cometic (.058 i think) headgasket, innovative T3/T4 57 trim .63 a/r 10.5 psi, inline pro mani, tial 38mm + bov, 2 1/2" charge pipe, 3" turbo back, dsm 440s, turbo edit chipped pm6 with a homemade base map, Fine tuned (max of plus or minus 5%) with a vafc.
my first pull was 185 hp/145 torq lol the best we got but didnt print was 262 </TD></TR></TABLE>
I am going to turbo setup with my B16a, How much potential do you think or power a B16a can produce. I know everyone says that TQ is not there strong suit but what do you think. I hope to hit over 450whp with my B series.
Old Aug 29, 2004 | 05:42 AM
alpha's Avatar
Very nice When do you plan on fully tuning your setup with the Turbo Edit software? The belt only jumped 75 degrees
Old Aug 29, 2004 | 07:21 AM
Default Re: B16a dyno results (0x64)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 &raquo;</TD></TR><TR><TD CLASS="quote">Very nice When do you plan on fully tuning your setup with the Turbo Edit software? The belt only jumped 75 degrees </TD></TR></TABLE>
i wanta tune as soon as they get the datalogging and teh high cam low cam resolution maps fixed. I also need a romulator and i dont think htey work with the new version of te yet
Old Aug 29, 2004 | 07:49 AM
nonvtecD's Avatar
Looks like hp was still climbing on that graph, up your limiter.
TurboB16A300Hpteg
Dec 21, 2007 11:08 AM
turbohf
Dec 3, 2007 10:47 PM
urbansi
Jun 9, 2007 02:20 PM
DeadVet
Jul 6, 2005 07:33 PM
touringteg
Oct 8, 2002 06:58 PM
