Where is my weakness in my setup?
2000 ITR
Turbo Stuff:
Full race kit (t3/67) (intercooler/piping is anodized, manifold/turbo is jethotted, dp is wrapped)
tilton twin disc clutch (ceramic)
1000cc percison injectors
hondata s200b
Walbro 255hp (i think this will be my downfall) - what is a good alternative?
Digital 6+ w/ all msd crap (stock wires)
Greddy Profec b (1st gen)
thermal 3" exhaust
Civic core C&R radaitor w/ 14" mr gasket fan (1800cfm)
Engine: (building this as we speak, should be done in 2 weeks, still waiting on parts and ordering)
Dart 84.5mm Standard Deck Block
ITR crank (should i micropolish and balance) - Isnt it already balanced?
Full race Rods (manley)
CP 84.5mm 9.0:1 compression
GE 84.5mm Head gasket
AEBS head studs
NEW timing belt, itr oil and water pump
ITR head, port and polish, 3 valve angle job, supertech valves/retainers/springs
Fluids:
Clutch = Motel 600, (was having problems with clutch slave cylinder, heating up so much)
Brakes = ATS Superblue
Tranny = Stock honda fluid
Coolant = Stock honda coolant
Oil = Castrol 5w30 (for break in), Modil 1 5w30 super synthetic
What is more likely to fail?!?! Is this mainly a bullet proof setup for lets say just normal street beating.. only 10psi..
Turbo Stuff:
hondata s200b
thermal 3" exhaust
AEBS head studs
Fluids:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy »</TD></TR><TR><TD CLASS="quote">I don't see a new clutch in that list, so I will bet that burns out first.</TD></TR></TABLE>
"tilton twin disc clutch"
The weakness is gonna be having to pay off that credit card bill?
****, looks good to me...maybe axles?
I think its cool you have a dart setup for a 10psi t3/67 street car. You really take the "do it right the first time" thing to heart huh?
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
I still hold the belief that you push X or something.
Good God, never seen a college student (I'm one, and I know a lot on here) with that kind of budget and "his own" money.
controlling traction is gonna be your weakness, id go w/ some type of boost per gear/speed boost controller, cuz i bet you wont just stop at 10 psi on the street
1.) Traction
2.) Axles. I didn't notice them listed.
3.) LSD, I know the R has one compared to a Quiaffe they are weak.
Other then that it's a awesome set-up, it should do you very well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase »</TD></TR><TR><TD CLASS="quote">controlling traction is gonna be your weakness, id go w/ some type of boost per gear/speed boost controller, cuz i bet you wont just stop at 10 psi on the street
What this guy said. I know the avc-r has gear dependent boost settings, but i'm not sure of another.
Edit...avcr is rpm based boost control
And i want meant about the 10psi. The car will more then likely be driving on 10psi daily..
I dont want to put the limits of pump gas, on street, there is no point imo..
I do want to run the car at local events, in the street class..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RacerXI »</TD></TR><TR><TD CLASS="quote">
What this guy said. I know the avc-r has gear dependent boost settings, but i'm not sure of another. </TD></TR></TABLE>
i thought the avc-r was only RPM/Boost??
Smarter than you
You just have to know at what MPH you switch to the next gear, and you can do GBB like that. Im not a big fan of the AVCR boost uncontroller. Id rather go w/ something simpler like a dual stage turbo XS.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo »</TD></TR><TR><TD CLASS="quote">
i thought the avc-r was only RPM/Boost??</TD></TR></TABLE>
The AEM EMS does this..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 »</TD></TR><TR><TD CLASS="quote">You just have to know at what MPH you switch to the next gear, and you can do GBB like that. Im not a big fan of the AVCR boost uncontroller. Id rather go w/ something simpler like a dual stage turbo XS. </TD></TR></TABLE>
well if dual stage is the case, i could just use my profec b. just setup the high boost button
Edit...avcr is rpm based boost control</TD></TR></TABLE>
And Gear.
And Gear.
I do need the titlon hyraclic bearing upgrade..
anyone knows who will carry them??
I had previous problems with the stock slave cylinder failing, due to heat from my turbo..
Smarter than you
well if dual stage is the case, i could just use my profec b. just setup the high boost button</TD></TR></TABLE>
Profec w/ high boost button would be sweet. Cost effective, Proven, and consistant.
done
Jun 14, 2006 08:34 PM
done
Feb 4, 2006 08:27 AM
done
Oct 11, 2004 07:00 PM
