700whp Civic Coupe - B20VTEC
From one of our customers
Here is a Sneak Preview of my project.
I have been building my car for the last 2 years. Getting close to finally putting it together. Thought I would throw you guys some sneak preview pictures of it.
Its a 95 Civic Coupe, with a fully built B20/vtec, a huge turbo, and setup for SportFWD/ProAM-FWD rules NHRA and IDRC.
Also want to thanks Alex and John @ prostreetonline.com for helping me get the parts I need at good prices and awesome service!
We are looking to run mid 10's in the 1/4, and looking to put out 650 to 700whp
Some Basic Specs are.
Engine:
B20B Block
Golden Eagle Sleeves
B16A Head
JG Engine Dynamics Pro-Series Head (custom spec)
JG Sheet Metal Intake Manifold
Turbo:
Precision PT Series Turbo Custom
Revhard Tubular T4 Race Manifold
Tial 46mm Wastegate (prostreetonline.com)
Tial 50mm Blow Off Valve (prostreetonline.com)
Precision 750hp Intercooler (31 x 10.5 x 3.5
Fuel Management:
AEM EMS (prostreetonline.com)
Precision 1000cc Injectors
Golden Eagle Fuel Rail
Aeromotive FPR (prostreetonline.com)
Ignition
MSD Digital 6 Plus (current) (prostreetonline.com)
MSD HVC Coil (prostreetonline.com)
AEM C2DI Ignition (coming soon) (prostreetonline.com)
Coil on Plug or aftermarket MSD Coils. (prostreetonline.com)
Drivetrain:
Tilton Cerametalic Twin Disk Clutch (prostreetonline.com)
Tilton Hydrolic Release Bearing (prostreetonline.com)
Quaife LSD
Gator Stage 3 Axles
JimFab Crossmember
Suspension Technique's Swaybars
Ground Control Drag Springs (prostreetonline.com)
Koni Yellows
25" x 8.7 x 13" M&H Slicks
Bogart Flylight 13" Drag Wheels.
24 x 4 x 15 Skinnys
Bogart Flylight 15" skinnys
Interior:
Sparco non-adjustable Seats (matching)
SFI Approved 5 point harness (prostreetonline.com)
8 point Roll Cage
Window Net
I dont have that many good pictures of the chassis yet, but here is some eyecandy.
Look for it at a track near you!
Engine:
B20B Block
B16A Head
Turbo:
Fuel Management:
Ignition
Drivetrain:
Quaife LSD
Gator Stage 3 Axles
JimFab Crossmember
Koni Yellows
24 x 4 x 15 Skinnys
Interior:
8 point Roll Cage
Window Net
Thanks guys!!
He is also going to be running our Pro Street Timing Belt Kit. We'll have a writeup on that once the motor is ready to be dropped into the chassis.
Daaammmn! That's a big *** turbo. Not to mention that that's a a bad *** combination with the motor you have and set up. It seems like you'll be opening up fresh cans of whoop *** on the street and at the track. Tight!
Looks like someone has a lot of parts without allot of power
lol
You are keeping the turbo specs secret as well as compression (pistons/rods), gas to be used, and bore??
Sounds like a sales advertisement to me
Where is the 700 HP?????
NICE PARTS EITHER WAY
lolYou are keeping the turbo specs secret as well as compression (pistons/rods), gas to be used, and bore??
Where is the 700 HP????? NICE PARTS EITHER WAY
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RA166E »</TD></TR><TR><TD CLASS="quote">Bad ***!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prostreetonline »</TD></TR><TR><TD CLASS="quote">JG did the headwork
DOH!
So is the turbo going to blow right into the timing belt/waterpump?
</TD></TR></TABLE>DOH!
Hey that setup looks like mine!
I also want to give thanks to CivicRyda2k for hookin it up with the Precision goodness. He's a precision pimp!
Jay
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si2die4 »</TD></TR><TR><TD CLASS="quote"> compression (pistons/rods), gas to be used, and bore??
Compression is 9:1 pistons, however with the headwork, it is looking to be about 9.3:1-9.4:1 Bore is 84.5mm CP Pistons, Pauter Rods. Used a GE O-ring'ed block.
The car isnt together yet. But should be in the next few weeks. Trying to hookup time with st00pid to tune the car too.
700whp is a far reach, and useless power in many ways, however the setup should be more than capable of it.
Jay
Jay
