i'm begging please help!!!!!!!!!!!!!!!
Old Aug 28, 2004 | 10:51 PM
vangc6780's Avatar
Default i'm begging please help!!!!!!!!!!!!!!!
my car keeps on overheating!!!!!!!!!!!!!!!!!!!
f%ck i tried everything.............
i just changed the thermostat and did a flush and the car still overheat!!!!!!!!!!!!!
first of all i have a b18c1 with a t3/t4.
also i have the fan running all the time and its still overheat when i'm stuck in traffic or if i'm cruising............
i'm running a block guard from race engineering.
is there a way to check if my headgasket is bad or not........
this sh%t is really bothering me alot so if some1 in here had this happen to them let me know what you guys did to get rid of the damn problem........
also i bleed the coolong system and i'm running a brand new fluidyne radiator...
please help!!!!!!!!!!!!!!!!!!!!!!
Old Aug 29, 2004 | 12:02 AM
vangc6780's Avatar
Default Re: i'm begging please help!!!!!!!!!!!!!!! (vangc6780)
someone please
Old Aug 29, 2004 | 12:20 AM
crx2fast's Avatar
lets hope that block gaurd isnt doin it. have you done a compresion test. could be a warped head. not to sure though
Old Aug 29, 2004 | 12:28 AM
StreetProjectz's Avatar
Default Re: i'm begging please help!!!!!!!!!!!!!!! (crx2fast)
here is a trick i was told, cut out the center section of the thermostat that way there is a lil restriction and put it back in. run a whole bottle of red line water wetter. my car did the same thing but its good now. and maybe get a new fan from pep boys they work good and arent as expensive as FAL.
Old Aug 29, 2004 | 09:09 AM
johnmay19's Avatar
Default Re: i'm begging please help!!!!!!!!!!!!!!! (StreetProjectz)
How about you water pump. If the coolant is not flowing it won't cool!
Old Aug 29, 2004 | 09:18 AM
boosted_dc2's Avatar
Default Re: i'm begging please help!!!!!!!!!!!!!!! (johnmay19)
how do you know its overheating??? what signs is it giving, over flow filling etc.
Landon
Old Aug 29, 2004 | 10:10 AM
vangc6780's Avatar
Default Re: i'm begging please help!!!!!!!!!!!!!!! (boosted_dc2)
the temperature gauge is usually all the way up when i'm just cruising around for a while...
the water pump is also brand new when i had my block built they put in a new water pump...
i also had my compression check about a month ago and it was 190 across the board...
Old Aug 29, 2004 | 10:12 AM
m R g S r's Avatar
If the gauge is all the way up and you drive around like that, then you probally did major damage, like warped head and possibly block too. . .
Old Aug 29, 2004 | 10:13 AM
MidShipCivic's Avatar
Why don't you start doing an elimination process.
Xhoops23
11
Jul 24, 2013 11:27 AM
JigsN Joints
Mar 20, 2011 07:36 AM
turbotegy10
May 20, 2010 05:06 PM
Ronin150
10
Nov 22, 2004 08:59 AM
kun3racer
Oct 21, 2004 01:48 PM
