IS the SOHC and DOHC DP the same ...
Old Aug 31, 2004 | 04:56 PM
Red_Greddy_Si's Avatar
Default IS the SOHC and DOHC DP the same ...
on the greddy turbo kits????? I am not really worried about the length or the flange but more if it bolts up the same and has the same routing past the oil pan and such. thank you all for the help. BTW if they are close to the same KTeller has one that is a 2-2.5 flare that I will purchase. thanks again
Old Aug 31, 2004 | 06:29 PM
Default Re: IS the SOHC and DOHC DP the same ... (Red_Greddy_Si)
anyone??????
Old Sep 2, 2004 | 02:21 PM
all you boost heads and nobody knows
Old Sep 2, 2004 | 02:22 PM
Alex Buchka's Avatar
doesn't greddy have a customer service line you can call and ask?
Old Sep 2, 2004 | 03:01 PM
Turbo E's Avatar
Default Re: IS the SOHC and DOHC DP the same ... (jag_e_fattig)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jag_e_fattig &raquo;</TD></TR><TR><TD CLASS="quote">doesn't greddy have a customer service line you can call and ask?</TD></TR></TABLE>
*just starts laughing*
CS dept, yes. help, no.
i dont think the pipes are the same as they use different turbos AND the block heights are diffferent. get a custom one made up if you need one. the Greddy pipe is a tiny POS.
Old Sep 2, 2004 | 03:46 PM
lanojp1's Avatar
greddy doesnt answer their phones...ive called many times...
93b18civic
Jan 16, 2005 12:14 PM
maddog20
Nov 13, 2004 11:52 AM
mooseknuckle
Dec 1, 2003 09:17 AM
Sohc Driver
Oct 17, 2003 01:23 PM
Pengo
Jun 14, 2002 07:08 PM
