afc hack..CEL
Old Aug 30, 2004 | 12:25 PM
DruWO's Avatar
Default afc hack..CEL
i don't have my turbo in yet, but i installed my 460's and my afc to make my install easier this weekend. i got everything in, and everything is wired up correctly. when i started up the car, it threw a CEL (codes 71, and 72) random misfire in cylinder 1 and 2.
my setting is -48 all across...
240/460= .52
1- .52 = .48
So -48 should put me back to stock right? could the injectors for cylinder 1 and 2 be clogged or something?
Edit: or maybe i mixed up the wires from cylinder 1 and 2. Can someone tell what order the colors wires go for the injectors in a d16y8?
Old Aug 30, 2004 | 01:08 PM
DruWO's Avatar
Default Re: afc hack..CEL (DruWO)
i just messed with the settings...put it to -35 all across, and runs almost like stock now, but the CEL is still on, and now its 71 72 73 74.....
input anyone?
Old Aug 30, 2004 | 01:13 PM
beepy's Avatar
You ran too lean with -.48. You have to remember that those big injectors need more time to open. Generally speaking you have the formula right but you want to subtract .9 instead of 1.0.
240/460 = .52
(.52 - .9)*100 = -38%
You are running too rich on -35%, but not enough to be causing misfire codes. What plugs are you using, and what gap?
Old Aug 30, 2004 | 01:27 PM
DruWO's Avatar
stock plugs gapped at the stock settings i guess...can't tell you off the top of my head.
it didn't throw the cel until the injector install though, so i know its not the plugs. do you think bad seals around the injectors can cause this?
Old Aug 30, 2004 | 01:36 PM
beepy's Avatar
Default Re: (DruWO)
If you are running richer than stock with the stock plug gap and the stock ignition you will get misfires.
If you don't have a wideband to use, be safe and set the plugs to the 0.030" you'll need to use for the turbo anyway.
Old Aug 30, 2004 | 06:51 PM
DruWO's Avatar
anymore input?
PhoenixDownVII
Jun 7, 2009 07:03 PM
teppichkopf
May 31, 2007 03:31 PM
maxxd97
Nov 28, 2006 09:47 AM
crum
May 30, 2006 09:55 PM
JohnShaft
Sep 5, 2001 02:01 PM
