MAP check engine code.
Old Aug 30, 2004 | 01:12 AM
Root79's Avatar
Default MAP check engine code.
OBD-0 ECU, D15B2 engine, mini turbo
Can't find out how lie to map. When boost gose more than 0 check engine code throwing.
We instal one way valve which open till 0 bar, then just closing. That dose not work.
Any ideas?
Old Aug 30, 2004 | 01:18 AM
eg6T's Avatar
Default Re: MAP check engine code. (Root79)
its kind of hard to understand..0 bar?that would be no boost.get a "missing link" map bypass
Root79's Avatar
Need help Guy's!
Old Aug 30, 2004 | 01:20 AM
Root79's Avatar
Default Re: MAP check engine code. (eg6T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T &raquo;</TD></TR><TR><TD CLASS="quote">its kind of hard to understand..0 bar?that would be no boost.get a "missing link" map bypass</TD></TR></TABLE>
Yes, missing link. How to made it?
Old Aug 30, 2004 | 01:41 AM
Root79's Avatar
Car can't run.
Maybe somebody can explain how works this mising link!
Old Aug 30, 2004 | 01:58 AM
Tchleung's Avatar
You should REALLY have researched everything involved in turboeing a car insetad of jsut buying pats and slapp it on.. this is how ppl blow things up. 0 knoweldge, and 0 budget.
Is your map sensor firewall mounted or TB mounted? And what are you using for fuel management
Old Aug 30, 2004 | 02:31 AM
Root79's Avatar
Default Re: (Tchleung)
The map sensor is firewall mounted. It's the car of my friend and his project. I'm just helping to him. And all that turbo thinks interesting me too.
The D15B2 engine is mono injected engine, he add two injectors which controls with somekind of electronic devaice.
Old Aug 30, 2004 | 03:10 AM
eg6T's Avatar
Default Re: (Root79)
go here http://www.overboost.com/obs/product.asp?pid=5511
Old Aug 30, 2004 | 07:15 AM
Tchleung's Avatar
Yep get taht missing link for the car that the guy linked from Synapse. Damn he's still using dual point injection system.. Crazy lol.
Cimburke23
Sep 13, 2004 05:23 PM
silverbulletgsr
Jan 21, 2004 12:59 AM
dohcvtec717
Mar 31, 2002 11:49 AM
JM Performance
Dec 5, 2001 09:30 AM
Turbo EG6
Aug 19, 2001 05:04 PM
