Exhaust manifold pressure (Full-Race Manifold)
Curiousity: What kind of EXHAUST MANIFOLD PRESSURES are people running with a Full-Race equal length tubular manifold, T3/T04 turbo lets say .63AR for sake of argument. 1.8L B series motor, idle-8500 RPM range.
Pressures in vaccum while cruising?
Pressures at WOT spooling turbo?
Pressures at WOT/Full boost with wastegate open?
Thanks in advance,
-Dave
Thanks in advance,
-Dave
Smarter than you
Re: Exhaust manifold pressure (blundar)
ummm, im just interested who is actually able to datalog this information on this website ahahaha....
i know of a few that can but they are not right now.
Smarter than you
Re: (blundar)
yeh, the turbo was just a little bit bigger then a t3/t4 and the car was on meth hehe. but it might help ya. btw, what exactly are ya trying to figure out by knowing the back pressure?
weve only tested it on two race cars so far, and one was a .96 ratio, the other was about .97. very similar setups
Smarter than you
Re: (blundar)
Cool, well hopefully your idea w/ the wastegates will work and help out w/ the exhaust back pressure.
Are you going to be able to datalog this on your set up? I think its going to be hard finding this info for a t3/t4 turbo. You might just end up having to do the testing yourself if you don't wanna just go w/ the "what already works" path.
Casey: I'm not local to you. Shipping you a motor, turbo manifold, turbo for testing would be prohibitively expensive. 8.5:1 Compression stock bore B18B honda motor, Full Race Manifold
Geoff: I'm interested in the exhaust backpressure at different conditions, particularly the wastegate-open full boost condition. How much boost were you running to get these .96/.97 Intake manifold/exhaust maniflold ratios? Without knowing how much boost you were running, that's not helpful information.
Re: (blundar)
DIRep: I'll probably end up testing this myself, yes. I'm trying to get some idea of how much backpressure a T3/T4ish turbo generates once fully spooled and the majority of exhaust is bieng dumped out of a wastegate. I know this will vary with my particular setup. I'm just trying to get a ballpark figure so I have some better guidelines for engineering the rest of the motor. (i.e. piston compression ratio)
There are very good things to be had with an intake manifold / exhaust manifold pressure ratio greater than 1.0, as I'm sure some already know...
Re: (blundar)
when i say .96/.97 i am reffering to this being equivalent to 45 psi intake, 43 psi exh and so forth.
I think we should agree to set one nomenclature straight, whether it is exh/int or int/exh. I have always seen exh/int. ideal is below 1.0 for no reversion
The ratios vary according to shaft speed of curse, but this was an average taken on a car with a very large turbo and anywhere from 32 psi to 48 psi
Intake
exhaust
This ratio will be > 1 when there is more boost than backpressure. This ratio will be less than one when there is less boost than backpressure.
Do you+I have our numerator/denominators switched?
The data that you are describing is interesting, although everything I've turned up in my research suggests there will be considerably more variation between the wastegate closed/wastegate open at equilibrium states.
Am I misunderstanding you or...?
exhaust
Smarter than you
Re: (blundar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blundar »</TD></TR><TR><TD CLASS="quote">DIRep: I'll probably end up testing this myself, yes. I'm trying to get some idea of how much backpressure a T3/T4ish turbo generates once fully spooled and the majority of exhaust is bieng dumped out of a wastegate. </TD></TR></TABLE>
hehe, id bet it is alot. As the t3/t4 turbo's seem to overcome bad wastegate placement pretty easily.
Re: (blundar)
yes we are talking about the inverse of one another. I was referring to
exhaust
intake
i expect your test to work much better with a restrictive (aka small) turbine housing than with our test. i think you would like the turbine housings we have been working on casting
exhaust
intake
Re: (Full-Race Geoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Geoff »</TD></TR><TR><TD CLASS="quote"> i think you would like the turbine housings we have been working on casting </TD></TR></TABLE>
with a nice, smooth WG dump dangling off it I hope? Someone needs to make that
Re: (Bailhatch)
You will never find out what you want to know, unless you run the same exact
motor with the same exact load and temp. b.p. and so on.You can only get A ball park.
Re: Exhaust manifold pressure (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo »</TD></TR><TR><TD CLASS="quote">we'll be tesing exhaust back pressure with Ben Strader and Direp here very soon. We have everything set up with Autronic.</TD></TR></TABLE>
:drool:.... autronic...
We tested this on my T3 Full Race manifold and my T4 Full Race mani, Let me see if I can look up the #s. My old T3/60-1 .82 A/R was kinda high of course, the T4 different story. I will check and see if my tuner and machinist still have the #s.
Actually there is still a bung in the manifold prior to the turbine to check still, we can do testing next time on the dyno also.
wade
09-18-2011 08:11 PM
