PT-67?? Anybody have a dyno chart with it??
I was wanting to know if anybody has made good power with this turbo. I wanna see what kind of power it is capable and when the power is made. If you have a dyno chart with this turbo can you please post it, thanx...
Re: PT-67?? Anybody have a dyno chart with it?? (anothaRRR)
I have the same thing, a Full Race/Garrett T67 .68 A/R P trim turbine on a lil ole bitty 84mm bore B16A with stock 77.4mm stroke
The diff in the two graphs is lower one B16A cams higher is ITR cams
Re: PT-67?? Anybody have a dyno chart with it?? (Boostfed)
Damn, thats very impressive on a b16. I have a 84mm b18c1 and hope to push very similar power to that. What psi was the 616 made with?? What is comp. ratio?? Thanx man.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anothaRRR »</TD></TR><TR><TD CLASS="quote">Damn, thats very impressive on a b16. I have a 84mm b18c1 and hope to push very similar power to that. What psi was the 616 made with?? What is comp. ratio?? Thanx man.</TD></TR></TABLE>
9.5:1 CR 27-28psi
9.5:1 CR 27-28psi
Re: (pimpintyperintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pimpintyperintegra »</TD></TR><TR><TD CLASS="quote">is that the turbo in Full-Race's 700 whp kit?</TD></TR></TABLE>
Yes and that is my car they have displayed for the Stage 4 kit too!
Re: PT-67?? Anybody have a dyno chart with it?? (st00pid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by st00pid »</TD></TR><TR><TD CLASS="quote">You need to just put that damn dyno sheet in your sig </TD></TR></TABLE>
Dynos in the sky!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed »</TD></TR><TR><TD CLASS="quote">I have the same thing, a Full Race/Garrett T67 .68 A/R P trim turbine on a lil ole bitty 84mm bore B16A with stock 77.4mm stroke
The diff in the two graphs is lower one B16A cams higher is ITR cams </TD></TR></TABLE>
Nice!
Nice!
well im getting ready to order the full-race t4/t67 p-trim .84ar. is there any differance between the pt67 and full-race t4/t67? i realy dont think there is. i would like to run up to 25lbs of boost to reach 600hp.
Re: (exospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx »</TD></TR><TR><TD CLASS="quote">We made 500 HP on an 84mm LS VTEC 10.8:1 compression with the PT67 on 18psi</TD></TR></TABLE>
wow
wow
