99 si turbo exhaust leak??
i just finished puttin my turbo kit today with exhaust ne everything, i have a 255 fuel pump also, but i found a very small exhaust leak on my down pipe..and my turbo isnt spooling right and also vtec wont engage correctly, is this from the leak or could it be another problem? help plz..
Re: 99 si turbo exhaust leak?? (hitvtecgetloud09)
Exhaust leak would not effect VTEC. If the leak is before the turbo, then that would effect spool times, but if it is after, it would only help it (By freeing up some back pressure)
Re: 99 si turbo exhaust leak?? (m R g S r)
well the leak is on the down pipe. and ive had the turbo on there b4 with the same set up, but its spooling at higher rpm this time then it did last time i had my set up... would boosting at 4 instead of 7 which is wat my last set up was boosting cause this? problem?
