What makes a turbo kit A/C compatible?
Old Oct 28, 2004 | 04:46 PM
AdvanTech's Avatar
Default What makes a turbo kit A/C compatible?
Sorry for the simple question, but the search button doesn't allow 3 letter words.
My friend likes the PeakBoost turbokit, but I see it is not A/C compatible.. Is there any way to make it compatible?
Thanks for your help!
Old Oct 28, 2004 | 05:20 PM
95turboex's Avatar
Default Re: What makes a turbo kit A/C compatible? (AdvanTech)
A/C compatible just means that the manifold positions the turbo far enough towards the passenger side of the car that the turbo and downpipe will clear the A/C compressor and condensor fan.
pvt_awol's Avatar
What makes it compatible or not, is where the manifold places the turbo. On most Hondas the A/C hangs off the front of the engine with the exhaust manifold right next to it. When you put a turbo mani on there, the turbo usually wants to occupy the space that the A/C compressor is in. And if the turbo doesn't, then the downpipe off of it does.
So, a lot of companies push the turbo further to the passenger side (USDM) of the car, and give you a smaller downpipe, and that will generally clear the A/C.
If a kit says not compatible with the AC, then the manifold is wanting the turbo to take up that space, or the downpipe is really big. For instance, the DRAG 3 kit gives you a 2.5" downpipe to clear the AC, but if you want a 3", you gotta ditch it. (unless you fab up something yourself) As for the turbo actually "messing" up your AC, that isn't the case. It's simply a matter of space available.
Old Oct 28, 2004 | 05:21 PM
pvt_awol's Avatar
Default Re: What makes a turbo kit A/C compatible? (pvt_awol)
ahhh crap, that dood posted before I was finished typing.... nutz.
Old Oct 28, 2004 | 05:25 PM
AdvanTech's Avatar
I see, thanks for the quick replies
So basically we'd need a new exhaust manifold to clear it AND a different dp to fit it, is that right?
Old Oct 28, 2004 | 05:41 PM
The Destroyer's Avatar
Default Re: (AdvanTech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdvanTech &raquo;</TD></TR><TR><TD CLASS="quote">I see, thanks for the quick replies
So basically we'd need a new exhaust manifold to clear it AND a different dp to fit it, is that right?</TD></TR></TABLE>
Yeah and maybe a new DP depending on the mani/setup.
EDIT: Search does allow 3 letter words, it doesnt allow 2 letter words.
Old Oct 28, 2004 | 05:43 PM
AdvanTech's Avatar
Default Re: (Vtaaak y0)
So basically we'd need a new exhaust manifold to clear it <U>AND a different dp to fit it</U>, is that right?
Thanks for the reply though
Old Oct 28, 2004 | 05:46 PM
95turboex's Avatar
Drag and Revhard both make very nice cast manifolds that are both A/C compatible. Be careful if you look at a tubular or a thin cast manifold, some of them are cheaply made and can crack. Most people recommend a good thick cast manifold for a street car.
Old Oct 28, 2004 | 05:47 PM
PrettyLude's Avatar
south florida performance
Old Oct 28, 2004 | 05:49 PM
AdvanTech's Avatar
Well my friend has $$ to spend so he's thinking of going all out with an A/C compatible Full-Race manifold.
Thanks for the reply though </TD></TR></TABLE>
You edited it.
Old Oct 28, 2004 | 05:51 PM
AdvanTech's Avatar
lol I honestly did not.. You just missed it.
Old Oct 28, 2004 | 07:50 PM
NotUrAvgSi's Avatar
not just because the DP also where the wastegate sits the A/C condensor would be in the way because the wategate would be hitting against it
Old Oct 29, 2004 | 03:22 AM
AdvanTech's Avatar
Default Re: (NotUrAvgSi)
But an A/C compatible exhaust manifold would take care of wastegate placement, no?
Old Oct 29, 2004 | 03:27 AM
FOrSfEd's Avatar
If you are looking for a good quality turbo kit that keeps ac I would def recommend the Full-Race kit, I think there is an ac version avaliable in the classifieds right now as a matter of fact.
Old Oct 29, 2004 | 03:30 AM
AdvanTech's Avatar
Default Re: (FOrSfEd)
I know how good full-race is, but peakboost is cheaper, and all that's missing is A/C compatibility. So I'm wondering if there's a way to change that without eventually getting to the price of a full-race kit
Old Oct 29, 2004 | 06:18 AM
fipracing_com's Avatar
Im running the ONEFAB setup on my 99SI, with A/C and Full 3"DP, turbo placement is excellent, and the build quality and customer service by Matt at onefabrication are second to none in my opinion.
Old Oct 29, 2004 | 06:31 AM
FOrSfEd's Avatar
Default Re: (fipracing_com)
You would have to end up changing the manifold and dp so in the end you would end up spending the same amount of cash. The one fab is also a good quality kit as well like stated above.
Old Oct 29, 2004 | 06:34 AM
NotUrAvgSi's Avatar
I say just ditch the A/C anyway unless you live somewhre really hot.
Old Oct 29, 2004 | 06:38 AM
AdvanTech's Avatar
Ha, I dunno about that. My friend wants is car to be comfortable well as fast
Old Oct 29, 2004 | 06:39 AM
AdvanTech's Avatar
Sounds like he'll have to dish out the extra cash for a full-race.. Thanks for all your help guys
tiemze
Jul 3, 2014 08:55 PM
420_EM1
Dec 21, 2013 03:22 PM
2000siturboR
Jun 4, 2009 08:00 AM
dtarvin
Jan 7, 2009 10:45 AM
stangkilla
Apr 30, 2002 03:04 PM
