Quick question to all D16 turbo ppl!
Old Nov 1, 2004 | 12:52 PM
mrx's Avatar
mrx
Default Quick question to all D16 turbo ppl!
Hallo,
quick question, quick answer please: how much whp can a stock D16A block handle?
a) with stock compression ratio and stock internals?
b) with reduced compression ratio and forced internals (rods, pistons)?
c) like b) but also sleeved?
Thanks
Malte.
Old Nov 1, 2004 | 01:01 PM
tgreaves's Avatar
Default Re: Quick question to all D16 turbo ppl! (mrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrx &raquo;</TD></TR><TR><TD CLASS="quote">Hallo,
Thanks
Malte.</TD></TR></TABLE>
Depends on alot of stuff..
Usally with a stock bottom end you can put out about 220hp or so with good tuning..
Sleeving and using forged internals will raise this up.. Why do you want to reduce your compression ratio?
Old Nov 1, 2004 | 01:05 PM
mrx's Avatar
mrx
Default Re: Quick question to all D16 turbo ppl! (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">Depends on alot of stuff..
Sleeving and using forged internals will raise this up.. Why do you want to reduce your compression ratio?</TD></TR></TABLE>
reducing the cr will reduce the stress on the engine and allows higher boost levels.
its only because a friend asked me whats possible with a d16a engine and because i only have experience with b16 engines i made this post... it's not so that i need exact numbers, only a range to get an idea of the possible power levels for different stages of engine buildup.
Greets
Malte.
Old Nov 1, 2004 | 01:06 PM
tgreaves's Avatar
Greets
How do you figure it will reduce stress and why do you want to run more boost?
Nicks95GSR
Oct 17, 2007 01:44 PM
92eg6
Jun 12, 2006 12:29 PM
KooK
Feb 14, 2006 12:13 PM
digital sol
Jan 20, 2006 03:27 PM
hybrid92b20
12
Feb 4, 2005 07:52 AM
