Greddy boost gauge stuck
Old Nov 2, 2004 | 06:29 AM
BlackT5's Avatar
Default Greddy boost gauge stuck
Got in my car yesterday and started her up, I immediately noticed my GReddy 52mm boost gauge was stuck past 2.0 bar. The car drove fine and once I hit boost, the gauge popped back and was fine...until I turned my car off. Now it's stuck past 2 bar and won't pop back. Anyone else had this problem?
I'm calling the GReddy tech line once they open, but i thought someone might have an easy fix? I checked all the connections, and all seem fine.
Old Nov 2, 2004 | 06:54 AM
Gravy's Avatar
Default Re: Greddy boost gauge stuck (BlackT5)
well being a greddy dealer i will tell you that their customer service isnt good at all. they will most likly tell you to send it back through the shop you purchased it from to see if they will warranty the gauge. and be ready to wait.
Old Nov 2, 2004 | 07:04 AM
Johnyquest's Avatar
Default Re: Greddy boost gauge stuck (Gravy)
I don't know if your gauge in question is electronic or mechanical... but if it's electronic I know there are a way to reset them. I can't help you with manual -- It just must have **** the bed.
Matt
Old Nov 2, 2004 | 07:14 AM
BlackT5's Avatar
Yeah, it's the electronic one..has the small sensor sender unit...it's less than a year old and 6 months of that, my car was off the road. I'm still trying to remember where I bought it from, I KNEW i should have bought it locally
Old Nov 2, 2004 | 10:21 AM
BlackT5's Avatar
anyone else had this problem?
Old Nov 3, 2004 | 05:14 PM
R134's Avatar
Default Re: Greddy boost gauge stuck (Johnyquest)
Can you tell me how to reset the electronic boost gauge or you just heard it can be done? I have the same problem.
Old Nov 3, 2004 | 05:48 PM
Drew Peacock's Avatar
Default Re: Greddy boost gauge stuck (R134)
The positive and negative wires aren't touching or loose?
Old Nov 3, 2004 | 06:49 PM
R134's Avatar
Ok, fixed it. Wired it wrong. Just shook the crap out of the gauge and the needle popped back.
Old Nov 3, 2004 | 07:00 PM
Default Re: Greddy boost gauge stuck (turbozxi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbozxi &raquo;</TD></TR><TR><TD CLASS="quote">The positive and negative wires aren't touching or loose? </TD></TR></TABLE> A beer would be nice.
Old May 19, 2010 | 07:38 PM
thegatekeeper14's Avatar
mine is now stuck past 2 bar also....
Old May 25, 2010 | 11:20 AM
BlackT5's Avatar
Does it correct itself once you hit boost? If not, it might have **** the bed.
For me, it was simply a matter of rewiring it. I originally had the red power wire connected with the orange ignition wire, but once I ran the red wire to a constant 12V source it was fine.
You can get the manual here if needed. http://www.greddy.com/img/PHP/products/pdf/702.pdf
Drew Peacock
Jan 29, 2005 10:31 AM
keebler65
Jan 6, 2003 07:45 PM
GorData
Jul 5, 2002 02:52 PM
VTC_CiViC
Jun 1, 2002 10:36 PM
