my turbo setup progress almost finished
Old Oct 28, 2004 | 10:01 PM
ludetech
Guest
Posts: n/a
Default my turbo setup progress almost finished
here's my setup I've been building for the past few months.
It has completely consumed me. what I originaly started out and assumed would be around a 4.4k project has turned into a 7k project w/o a motor build.
in the pictures you can see this
pwr 550hp fmic
pwr civic dual core radiator
apexi n1 3"turbo muffler
onefab 3" downpipe
onefab equal length manifold
tial 38mm wastegate
fast-turbo braided oil feed and drain kit
precision sc61 .63/.60 a/r
whats not in the pictures is this
aem ems with acer 340t slimbook laptop
rc 750cc injectors
golden eagle fuel rail/vacume manifold
greddy catch can
greddy turbo timer
greddy el 60mm boost & egt gauges
walbro 255 fuel pump
blitz dd bov
sx high flow 6an fpr
and here is a quick pic of where it sits now.
to matt at onefab
ben at importparts.com
both you guys kick ***
Old Oct 28, 2004 | 10:14 PM
TeStUdO's Avatar
Nice setup. H22?? how much power you looking for???
Old Oct 28, 2004 | 10:15 PM
evosol's Avatar
Default Re: my turbo setup progress almost finished (ludetech)
looks good!
ive never heard of Eatonville. It must be another one of those small towns in Washington.
Old Oct 28, 2004 | 10:50 PM
Kwuaymaikrup's Avatar
Default Re: my turbo setup progress almost finished (evosol)
Right on, good to see another local car coming up
Old Oct 29, 2004 | 02:53 AM
Finland's Avatar
It's only money bro. Money is useless unless you spend it on something that gives you joy. Looks like a nicely planned setup.
Old Oct 29, 2004 | 08:22 AM
Turbocivic94's Avatar
Default Re: (syckturboITR)
Very Nice Setup
put together very well
Old Oct 29, 2004 | 09:38 AM
EJ1 wilcox's Avatar
Default Re: (Turbocivic94)
Wow
It's funny how turbo projects get really expensive really fast!
Top notch products you got there, I believe you will be very happy with that setup!
Old Oct 29, 2004 | 11:59 AM
ludetech
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by syckturboITR &raquo;</TD></TR><TR><TD CLASS="quote">It's only money bro. Money is useless unless you spend it on something that gives you joy. Looks like a nicely planned setup.</TD></TR></TABLE>
yeah I totaly agree with you on that one.
Thanks for all the compliments guys, I did quite a bit of time into the thought of this kit. I also had alot of help from my freinds in ludeconduct and Matt at onefab
Old Oct 29, 2004 | 12:00 PM
ludetech
Guest
Posts: n/a
Default Re: (TeStUdO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO &raquo;</TD></TR><TR><TD CLASS="quote">Nice setup. H22?? how much power you looking for???</TD></TR></TABLE>
The most I can possibly hit on pump gas. I'll probably end up upgrading my wastegate before I retune it on high boost. I'm hoping for around 500whp on 92 octane
Old Oct 29, 2004 | 12:21 PM
11psiTurboSI's Avatar
Default Re: (ludetech)
That turbo manifold looks so sick
Old Oct 29, 2004 | 01:00 PM
whp
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludetech &raquo;</TD></TR><TR><TD CLASS="quote">
It has completely consumed me. what I originaly started out and assumed would be around a 4.4k project has turned into a 7k project w/o a motor build.</TD></TR></TABLE>
so are you running a stock block/sleeves?
Old Oct 31, 2004 | 10:19 PM
ludetech
Guest
Posts: n/a
Default Re: (complete)
yeah, you gotta start somewhere and I figured I'd build the setup first then build the motor. I can work the kinks out on the turbo setup on this motor and rebuild when its good. wanna ship it off to benson here soon
Old Oct 31, 2004 | 10:31 PM
Maveric's Avatar
sweet setup, good luck, correct me if im wrong but isnt the perk of getting the onefab, the ability to retain a/c? which you dont have?
either way clean setup
Old Oct 31, 2004 | 11:42 PM
5w20's Avatar
So true.
Old Nov 1, 2004 | 05:44 AM
Matgallis's Avatar
Default Re: (maveric)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maveric &raquo;</TD></TR><TR><TD CLASS="quote">sweet setup, good luck, correct me if im wrong but isnt the perk of getting the onefab, the ability to retain a/c? which you dont have?
</TD></TR></TABLE>I don't believe that's the a/c compatible one.
Old Nov 1, 2004 | 06:34 AM
whp
Guest
Posts: n/a
The most I can possibly hit on pump gas. I'll probably end up upgrading my wastegate before I retune it on high boost. I'm hoping for around 500whp on 92 octane </TD></TR></TABLE>
can you explain to me how you are going to pull this off on stock sleeves and 92 octane?
Old Nov 1, 2004 | 07:22 AM
B18C1CYA's Avatar
Default Re: (throwed)
the 500whp level seams way to high for pump gas, you might do it on race fuel,
Old Nov 1, 2004 | 07:45 AM
whp
Guest
Posts: n/a
Default Re: (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">the 500whp level seams way to high for pump gas, you might do it on race fuel, </TD></TR></TABLE>
yeah exactly and with stock sleeves how you prolly wont see anything over 375whp, i try'd to PM him with some advice but just got sarcasm, so good luck
Old Nov 2, 2004 | 05:26 PM
PrettyLude's Avatar
they have a couple of cars recently on the board making 500 whp on pump gas
Old Nov 2, 2004 | 06:40 PM
Syner-G-Racing LLC's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">they have a couple of cars recently on the board making 500 whp on pump gas</TD></TR></TABLE>
Im not doubting that you guys have seen some one post saying they hit 500+ on 92 but the chemical limits of this gas can not with stand the amount of compression with out pre detonation...unless they have a block pushing 300+ before it even sees boost (and thats 300+with displacement not compression). and if they did hit that number on 92 the timing was so freaking retarded that its pointless.
Im not arguing to start ****...I just dont want to see people trying to hit 500+ on pump gas.
Old Nov 2, 2004 | 07:59 PM
cxVtecC1's Avatar
Default Re: (Syner-G-Racing)
on stock sleeves thats tough im running similar setup on b18c with low boost stock an hopin for @310whp
Old Nov 2, 2004 | 10:19 PM
Default Re: (cxVtecC1)
Im making 250 with a offset test pipe on 9 psi, with out the test pipe I made 271 on pump gas and that was pushing the chemical limits of the gas with out severly retarding the timing. If I lower the compression with a larger headgasket and some head studs I can push 10-14 psi safely making about 300-320 hp.
Im sorry I didnt coment the first time...oustanding components you have collected there! dont stop there...go for broke and do the whole 9!
Old Nov 3, 2004 | 07:15 AM
ludetech
Guest
Posts: n/a
Default Re: (sleevedgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleevedgsr &raquo;</TD></TR><TR><TD CLASS="quote">
yeah exactly and with stock sleeves how you prolly wont see anything over 375whp, i try'd to PM him with some advice but just got sarcasm, so good luck </TD></TR></TABLE>
uh no you didnt dude............ and read where I said I was planning on working the kinks out of the turbo kit then building my motor. Does it make much sence to work the kinks out at 16psi....... no . 500whp on pump gas is possible and thats what Im shooting for. **** YOU noob for trying to be smart and make me look dumb.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow poke &raquo;</TD></TR><TR><TD CLASS="quote">
You are the Idot that cant read! Twice!
I would laugh at your *** too
Ledetec thats an awesome build you have there I am sure you will be able to reach your goals w/that setup U are deff right about the W/G, you will want to upgrade And B18C1CYA is right....It will be tough to get the full 500 on pump! Arround 400 is about as far as I would go on pump. 500+ on race gas
Its money well spent </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1033030
they did it on a b18 with 84.5mm bore on an sc61(same turbo I have)so why can't I do it. Stock h22 bore is 87.5 and I would bore to 88.5 and run 9.1 comp pistons as well.
Old Nov 3, 2004 | 07:54 AM
sourskittles's Avatar
Good luck to ya on the build up. Would you mind posting your dyno results when you get it tuned. I'd love to see exactly how much power that thing makes on pump gas. As for the motor thing, lets not get into that. It does seem a little outrageous, but at the same time I know of a guy that has pushed 400+whp out of a D-series. If he can get that type a power on that motor an H22 should be able to get 500+whp when the internals have been done. Keep us posted on your progress. :thumbup
Old Nov 3, 2004 | 08:35 AM
bomber's Avatar
Default Re: (sourskittles)
I'm confused...are we talking about 500hp on pumpgas, or are we talking about 500hp on pumpgas AND on stock block?
Also, are you worried about running out of injector? The h22's dont seem to be as efficient as the B series...
Stock ignition setup?
