going to the darkside...need help badly
2001 gsr with 37,000 miles
injen short ram, comptech headers, hks hi power exhaust
looking into drag gen 4 or revhard, maybe xs-engineering
looking to boost a steady 7 psi...with the occasional bump to 9-10 pounds for five minutes or so.
it is a daily driver. with the motor so new, i am not going to rebuild my engine yet, rather just drive with the turbo and eventually rebuild in around 6 months. what would be the best setup? i need a reliable daily driver turbo. looking to hit at or around 270 daily, and after build up hit a steady 300 every day. please help
suggestions appreciated.
Def...But if you wanna have a good daily driver...try and go for an APEXi kit or soemthing that will aloow you to maintain your A/C...Friend of mine made 320 hp with a stock LS vtec, RC 440s Apexi turbo kit @ 12psi and chrome ECU
im thinking
drag gen 4 turbo kit (based around a turbonetics t3/to4e turbo)
rc 310cc injectors
hondata s200b
denso iridium plugs
then eventually stroke bore and build motor, sleeve it, then run an aem ems and smoke vipers
rc 310cc injectors
hondata s200b
denso iridium plugs
