motor rebuild
Old Nov 2, 2004 | 01:36 PM
nomad_G3 Turbo's Avatar
Default motor rebuild
i currently have 98 gsr that is turbocharged i know i want to upgrade to a presicion sc61 turbo. does anyone have any suggestion on rebuilding the b18c1. i want to push about 400-500whp on a daily driver. went to the track for the first time didn't run as well as it should have but i got itch for more power!!
Old Nov 2, 2004 | 02:46 PM
11psiTurboSI's Avatar
Default Re: motor rebuild (nomad*gsrt)
try searching bro
Old Nov 2, 2004 | 02:47 PM
lanojp1's Avatar
theres soooooooooo many options when building that motor...
Old Nov 2, 2004 | 03:48 PM
turbosi03's Avatar
Default Re: (lanojp1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lanojp1 &raquo;</TD></TR><TR><TD CLASS="quote">theres soooooooooo many options when building that motor...</TD></TR></TABLE>
but if your to lazy to research for the most critical part of your motor here's what my homework got me:
-Benson sleeves
-84mm bore (you may want to go with 83mm)
-CP pistons
-Crower rods
-stock polished, balanced crank
-ACL main bearings
-ARP head studs
-OEM copper sprayed gasket
blueprint block using micrometers, dial bore gauge, stretch gauge (for rod bolts), and double check things with plasti gauge
good luck!
Old Nov 3, 2004 | 06:11 AM
thanks for the info
fatboy01
Honda Motorcycles
16
Mar 12, 2008 10:38 AM
nvmeplz
135
Dec 29, 2006 03:20 PM
dipset1
Oct 24, 2006 08:26 PM
DA-9mordef
12
Jun 22, 2006 03:07 PM
jman86
30
Jul 5, 2005 05:13 PM
