How to keep Intercooler Pipe Temp down???
Old Oct 31, 2004 | 11:17 AM
StolenTeg's Avatar
Default How to keep Intercooler Pipe Temp down???
Is there anyway to keep the intercooler pipe temp down, if i feel the pipe at the end of the intercooler it ice cold but when i feel like the pipe in the engine bay that mother ****** is HOT. I can feel that the engine release a lot of hot air flowing around with my hand, is there anyway i can keep the pipe cool?
Old Oct 31, 2004 | 11:19 AM
InTeGrA B18b1's Avatar
Default Re: How to keep Intercooler Pipe Temp down??? (StolenTeg)
when it goes through the intercooler the pipes after that should cool it down. thats what the ic is for. before teh intercooler is usually hot. if your worried you can get something to wrap the pipes up.
Old Oct 31, 2004 | 11:28 AM
StolenTeg's Avatar
Default Re: How to keep Intercooler Pipe Temp down??? (InTeGrA B18b1)
That what im saying, right after the intercooler is cold but before the throttle body it hot...
Old Oct 31, 2004 | 11:33 AM
PrecisionH23a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StolenTeg &raquo;</TD></TR><TR><TD CLASS="quote">That what im saying, right after the intercooler is cold but before the throttle body it hot...</TD></TR></TABLE>
Did you install the turbo on opposites day? I've heard of that happening before...
Basically you need to find a way to vent out some of the heat out of your engine bay. You can double stack washers the old hotrod way where the hoot attaches to the latch. This lifts the hood a bit at an angle and hot air will flow out of the compartment near the windshield. You can also try wrapping your piping with insulation wrap or thermal coat the piping.
Old Oct 31, 2004 | 12:09 PM
boosted92's Avatar
Default Re: How to keep Intercooler Pipe Temp down??? (PrecisionH23a)
If you have your upper charge pipe ceramic coated it will reflect some of the engine bay's heat and keep your IAT's a bit lower.
Old Oct 31, 2004 | 12:23 PM
sp0onfed's Avatar
Default Re: How to keep Intercooler Pipe Temp down??? (boosted92)
exhaust wrap works pretty good
Old Oct 31, 2004 | 01:59 PM
drvfast's Avatar
Default Re: How to keep Intercooler Pipe Temp down??? (sp0onfed)
I thought exhaust wrap would retain heat in the intercooler piping.
Old Oct 31, 2004 | 02:16 PM
m R g S r's Avatar
Default Re: How to keep Intercooler Pipe Temp down??? (drvfast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drvfast &raquo;</TD></TR><TR><TD CLASS="quote">I thought exhaust wrap would retain heat in the intercooler piping.</TD></TR></TABLE>
It does, that's why you shouldn't wrap it. I have aluminum piping to the TB, which helps get rid of some heat. But Mine is also still warm, I am going to do the washer trick soon too, Cowl induction style.
Old Oct 31, 2004 | 03:01 PM
_entropy's Avatar
Default Re: How to keep Intercooler Pipe Temp down??? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">
It does, that's why you shouldn't wrap it. I have aluminum piping to the TB, which helps get rid of some heat. But Mine is also still warm, I am going to do the washer trick soon too, Cowl induction style.</TD></TR></TABLE>
If you have normal IAT's on an intercooled setup your engine bay temps will be significantly hotter than the charge air temps, so it would be beneficial to insulate the pipe from absorbing any more heat.
Integspeed21
Sep 16, 2004 10:34 AM
Turbo-Honda
Jan 13, 2004 11:51 PM
GSR-T-
Nov 12, 2003 12:48 PM
brkrnu
Sep 17, 2003 09:01 AM
B6teen
Feb 16, 2002 09:23 AM
