EGT temp raised after installed new spark plugs.
I was using NGK Bcpr7es and my EGT was at 580 Celcius @ 80mph..10 Vacumm...
But after I changed to the NGK R5671a-9 gapped at .028 (a step colder?)...My temp goes up to 620 Celcius at the same speed...
Is this supposed to happen? And what's your EGT temp?
Re: (87GolfKart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 87GolfKart »</TD></TR><TR><TD CLASS="quote">Try adjusting your fuel...sound like you're running lean on fuel. Is your fuel pressure regulator up to the task? Try lowering the boost and see if the EGT cools down a bit.</TD></TR></TABLE>
bad advice, high egts are fine while cruising, actually 600 C even seems low.
Re: (87GolfKart)
I'm pretty sure I'm not running lean..600 c is kinda rich..I was just wondering why a step colder plug would raised temp..
Re: (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase »</TD></TR><TR><TD CLASS="quote">
you're right, thanks for correcting me...my brain totally didn't pay attention to the temp number that was given at all lol...i'm more used to wide ban a/f meters
RedRacerCivic
10-29-2004 06:30 AM
