opinion on using this for intercooler piping
Old Oct 31, 2004 | 09:29 PM
antiJDM's Avatar
Default opinion on using this for intercooler piping
i've been debating whether or not to use this stuff for intercooler piping...i know its ugly, but some parts stores offer it for pretty cheap.
http://www.jcwhitney.com/autop...10101
will it withstand heat and boost? will couplers make a good seal on them? my main concern isnt looks at all........more function over looks.
Old Nov 11, 2004 | 10:45 PM
BJOnewiper's Avatar
Default Re: opinion on using this for intercooler piping (2thousandcivic)
bump.
i'd like to hear some opinions on this too.
Old Nov 11, 2004 | 11:49 PM
DJ_SaNdOz's Avatar
Default Re: opinion on using this for intercooler piping (bjo)
It seems like it may disturb the airflow to me.
Old Nov 11, 2004 | 11:51 PM
NightRiderS2K's Avatar
In-N-Out Burger
I don't see why not. Why don't you try it out and tell us if it works or not
Old Nov 12, 2004 | 12:33 AM
lev16gt's Avatar
Default Re: opinion on using this for intercooler piping (NightRider-gsR)
yeah, you can try it if you want but it also seems to me that it will not have good air flow at all....it would probably be just as cheap (if that's what you're going for) to use some pipes & couplers from home depot or lowes or something. otherwise just get some pre-bent aluminum (or whatever you want to use) and make your own piping.
Old Nov 12, 2004 | 03:16 AM
b1ackc1v1c's Avatar
Default Re: opinion on using this for intercooler piping (lev16gt)
Just use the pre-bend piping that they sell on their...air flow will not be as efficient as if you used straight piping. Then again it would be a nice experiment
Old Nov 12, 2004 | 03:45 AM
StolenTeg's Avatar
Default Re: opinion on using this for intercooler piping (b1ackc1v1c)
How about can you bend those into a 90 degree or 180 degree, i try to and it didnt work. 2.5 aluminum pipe from jc whitney work...
Old Nov 12, 2004 | 03:49 AM
BJOnewiper's Avatar
Default Re: opinion on using this for intercooler piping (StolenTeg)
I know the JC Whitney sells pre-bent piping (45*,90*,and180*)
I was planning on using that, and hopefully not having to do anying bending myself.
Old Nov 12, 2004 | 07:14 AM
Blown90hatcH's Avatar
Check out Kteller.com too.
Old Nov 12, 2004 | 09:24 AM
PM-Performance's Avatar
Default Re: opinion on using this for intercooler piping (DJ_SaNdOz)
i dont see it being any worse than stock tubing for air boxes. same concept. I wouldnt run it though BootLeg
Old Nov 12, 2004 | 09:39 AM
Sonny's Avatar
I don't think that stuff will hold pressure. I've used something similar before and you could see exhaust leaking out of it when the engine was cold.
Might not hurt to buy a small piece and pressure test it.
Sonny
Old Nov 12, 2004 | 09:44 AM
Joseph Davis's Avatar
Default Re: (Sonny)
Sonny is correct, it won't hold pressure.
Tzarinque
Jun 29, 2007 07:39 PM
usdmcivic94
Mar 20, 2005 07:58 PM
RuskeR
Welding / Fabrication
Feb 4, 2005 11:57 PM
bmm89
Jun 12, 2002 04:13 PM
TurBoXBirD16
May 29, 2002 10:44 PM
