Honing Question
Old Oct 28, 2004 | 11:59 AM
IMPORTant Si's Avatar
Default Honing Question
I just recieved my 1.8 84.5mm Dart block today. I was reading that it hasn't been honed, and must be prior to installation. How much does honing usually take out of the block? Reason I ask, will I still be able to use 84.5mm pistons? Or will honing take the block past that?
-James
Old Oct 28, 2004 | 12:19 PM
yellowturbo's Avatar
are they talking about a soft honning ?? I dont know why they could give you a brand new block not honed ??
Old Oct 28, 2004 | 12:29 PM
Default Re: (yellowturbo)
Straight Honing I think. I believe is also must be decked .002"
Old Oct 28, 2004 | 12:53 PM
msmotorsports's Avatar
Default Re: Honing Question (IMPORTant Si)
A standard hone will usually create .0001 to .001" more bore. Justs depends on the machiner and how much you want to take out.
Old Oct 28, 2004 | 01:44 PM
Pondus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IMPORTant Si &raquo;</TD></TR><TR><TD CLASS="quote">I just recieved my 1.8 84.5mm Dart block today. I was reading that it hasn't been honed, and must be prior to installation. How much does honing usually take out of the block? Reason I ask, will I still be able to use 84.5mm pistons? Or will honing take the block past that?
-James</TD></TR></TABLE>
If you measure the cylinder bores, it's not bored out to 84.5mm from Dart, it's slightly less so you can take it to a machine shop for a final bore and hone, ensuring you get the correct clearance with your pistons. I have a NIB Tall deck Dart block and it was bored ~83.8mm when i got it, now i wait on my CP pistons to arrive before i get it bored to 85mm and honed( it's for a NA build). It also looks like it should be decked a few 0.001"
ringminion_blank
Aug 3, 2008 03:28 PM
Sean DM
Mar 3, 2007 06:40 AM
igotthaspirit
Nov 13, 2006 03:54 PM
CL SLeePeR
Apr 21, 2005 05:15 AM
cueballsi
Oct 9, 2004 05:43 PM
