boost creep
my set up: 99 d16y8:edelbrock kit, cut off the 2" flange at the end of the downpipe, no cat, 2.5" exhaust
boost will hold at 7psi until around 6K rpms then it will proceed to creep insanely, i think i saw 15psi once. i've been having this problem since i cut off the 2" flange, coincidential or not it really sucks...i tried moving the wastegate arm out but it still creeps to 10 from around a steady 5.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by willie_su2166 »</TD></TR><TR><TD CLASS="quote">couple reasons will cause creeping problem:
1) poor turbo manifold design.
2) leaking somewhere.
Thanks
will</TD></TR></TABLE>
Im thinking a leak would prolly lead to boost leak not boost creep. But I could be wrong
. It's prolly something with the wastegate/vacuum lines. Do you have a boost controller? If you don't, you SHOULD.
Thanks
why would i want one when it is rising on its own!? its set at 7 psi and creeps to 15...so if i get and raise it then it will creep until i blow up my engine....think so?
oh ok thanks...i thought thats what controllers were for. so then whats the purpose of a wastegate if its gonna creep on you? in my case the creeping only started when i took away all that backpressure from the stock exhaust/cat/2" downpipe flange
i will do some research on boost controllers
I am still having Creep/spiking problems. When the car was first turbo'd it would stay steady @ 9psi. A couple of days later it started spiking.(I have a boost cut set @ 11psi.) I have redone the vacum lines and installed a Boost controller. The problem still persists. I can't even get on the car hard because it will bang off of the boost limiter and bog. I am stumped. I feel your pain
Phil
Phil
i have a 94 integra ls with the same problem. I have a Tial wastegate with a 9psi spring and external dump, no boost controller. It will hold 9psi, but once i get near redline on a long pull it will hit almost 13psi. im kind of stumped other than just putting in an 8psi spring and then see how high it still wants to creap on me.
i called some garrett distributors and local turbo shops, they reccomend porting the wastegate hole. it is a major cause of boost creep. a boost controller will not help. you have to have the hole ported because the exhaust is overcoming the flapper. i'll let you all know when i get mine done.
http://www.zaxjax.com/TIIWastegatePorting.htm
http://www.gnttype.org/techare....html
a good way to determine how much room you have to play with is to shut your flapper, spray paint over it, then open it back up. you'll see where the O.D. of the flapper sits and you know how far you can port from the outside edge
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by willie_su2166 »</TD></TR><TR><TD CLASS="quote">Creeping and spiking are two different things, and spiking can be resolved by a good boost controler, however the creeping can't be solved by boost controler.
I tried to use a turboXS MBC and it didn't cure my boost spike problem. Any recommendations? Thanks
Phil
Phil
The way I feel is that turbo is so sensitive, any changeing weather condition can effect it, my car usually would spik on me 0.5 psi when weather is cold out, and I will tune the avcr to help a little bit, but once temperture come back up then I have to re-do it. so for the 0.5 psi spiking, I would just let it...
Accel Junky
Jan 25, 2004 07:50 PM
