building head only, bad idea?
Old Nov 2, 2004 | 09:20 AM
originalsin's Avatar
Default building head only, bad idea?
ok well i have an ls motor and eventually plan on turboing it, but i was thinking of building the head some, not totally sure with what i want to do, was thinking like new valves,springs and retainers and like port match on the exhuast side, but would it be a bad idea to build the head and not the bottom end? would anny1 recogmend adding something in or something not to do? looking for opinions
Old Nov 2, 2004 | 09:32 AM
turbosi03's Avatar
Default Re: building head only, bad idea? (originalsin)
for boost I would worry about building the bottom first.
Old Nov 2, 2004 | 09:34 AM
ok so upgrade pistons/rods and replace bearings?
Old Nov 2, 2004 | 10:13 AM
92BlackSi's Avatar
Default Re: building head only, bad idea? (turbosi03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">for boost I would worry about building the bottom first. </TD></TR></TABLE>
Old Nov 2, 2004 | 05:18 PM
PrettyLude's Avatar
you forgot to add sleeves to that list of yours
Old Nov 2, 2004 | 05:51 PM
im only looking to run 7-8psi
prolly like 200hp? maybe 250 down the road, im not looking to go crazy
Old Nov 2, 2004 | 06:02 PM
95GSRTT
Guest
Posts: n/a
Default Re: (originalsin)
then why build the motor at all??
Old Nov 2, 2004 | 06:48 PM
PrettyLude's Avatar
that's the thing i don't get sometimes, you spend all that money and just wanna make 250 or 300whp which is very easy
Old Nov 2, 2004 | 06:53 PM
lanojp1's Avatar
if ur gunna build, start at the bottom and work up...but if ur only going for 250 then why even bother...
Old Nov 2, 2004 | 08:02 PM
well im just loking for something that is going to be reliable at the same time, but i guess i can get that with good tuning, i just need ot piece together a turbo kit now
Old Nov 2, 2004 | 08:32 PM
JDM.Accord's Avatar
Default Re: (lanojp1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lanojp1 &raquo;</TD></TR><TR><TD CLASS="quote">if ur gunna build, start at the bottom and work up...but if ur only going for 250 then why even bother...</TD></TR></TABLE>
Yep, if you're gonna run into problems related to boost, its gonna be in the bottom end
fast92hatch
May 12, 2007 08:26 AM
sycamore
Aug 30, 2006 08:43 PM
tegasaurus
May 18, 2004 08:33 AM
tonesdef
Jun 11, 2003 05:47 PM
carl_aka_carlos
Aug 12, 2002 10:51 PM
