Help with JRSC
I bought a charger from someone on this forum and it came incomplete. Its missing the Fuel pressure regulator and a relay and pressure switch. I was wondering if I can you and FPR??? Also what is the main things that I need to put this kit on a GSR motor??? The kit is a GSR kit, just wanted to know what was the most important parts that I need.
If anyone can help or direct me to anyone that can help, please let me know.
What sort of engine management are you going to use? Do you want to use the FMU and boost swich/relay? You can order the stuff through Jackson/Moss but I'd reccomend looking into other options for management.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GITWIDIT »</TD></TR><TR><TD CLASS="quote">What sort of engine management are you going to use? Do you want to use the FMU and boost swich/relay? You can order the stuff through Jackson/Moss but I'd reccomend looking into other options for management.</TD></TR></TABLE>
what other options do I have??? I really dont want to go crazy with it. just something simple. But am open to other options. All i have now is the stock B18C1 in a EK with the stock ECU and VAFC
Something inexpensive and easy... VAFC. You'll spend just as much on the boost switch/relay/fmu that you would on a VAFC. Also check into to some shareware engine management if the funds are limited, ie:Uberdata or something.
