obd0-obd1(b18a-b18b)question??
Old Nov 1, 2004 | 07:38 PM
D-meet07's Avatar
Default obd0-obd1(b18a-b18b)question??
ok i have a 91 teg that is equiped with the stock b18a. Im purchasing the b18b that is obd1. If i wanted to keep it obd one could i get the obd0-obd1 harness with the p75 ecu and be fine??? im wondering b/c im going turbo here soon and ive heard the the obd1 is better for tuning.
thanx
Old Nov 1, 2004 | 07:46 PM
xenocron's Avatar
Default Re: obd0-obd1(b18a-b18b)question?? (turbo90lude)
you can retain all of the OBD0 stuff and use TurboEdit if you are going FI. TurboEdit is great for the LS non-vtec stuff. Its the VTEC stuff thats still being worked on thats not 100% yet...
but yes, you can buy a conversion harness, retain all of the OBD1 sensors and go with UD just the same
Old Nov 2, 2004 | 02:26 AM
D-meet07's Avatar
Default Re: obd0-obd1(b18a-b18b)question?? (xenocron)
I had a guy at a local dyno tell me that the obd0 suxs for chipping and that i sould convert to obd1. they use uberdata??
Old Nov 2, 2004 | 02:30 AM
D-meet07's Avatar
xeno did u not need a 3bar map sensor with the 13 lbs of boost???
Old Nov 2, 2004 | 05:47 AM
DaX's Avatar
DaX
Loved
Community Favorite
I'm using a B18A1 [obd0] in my VX [obd1]. I originally used a P75 ECU, am now using a P06 ECU [with Hondata], and have a P28 ECU on standby.
You should be fine using a conversion harness.
Old Nov 2, 2004 | 06:41 AM
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo90lude &raquo;</TD></TR><TR><TD CLASS="quote">I had a guy at a local dyno tell me that the obd0 suxs for chipping and that i sould convert to obd1. they use uberdata??</TD></TR></TABLE>
This guys a moron...he is saying it sucks because he doesnt know what he is doing when it comes to OBD0.
IMO its always better to stay with the OBD version you have, if you can unless its a matter of using VTEC. Right now, the OBD1 VTEC code is just better.
Old Nov 2, 2004 | 06:43 AM
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo90lude &raquo;</TD></TR><TR><TD CLASS="quote">xeno did u not need a 3bar map sensor with the 13 lbs of boost???</TD></TR></TABLE>
No, i used the stock map sensor surprisingly and saw steady 11.7-11.9 AFRs in the upper boost ranges.
Put down the #'s in my sig at Boosted-Hybrid's shop in Easton, PA on his dynapack. My compression test that day yielded
190 100 190 210
Old Nov 2, 2004 | 11:44 AM
D-meet07's Avatar
so the obd0 is ok???? what about uberdata and the stock ecu. I kind of feel the same way about swaping ecu's and i didnt want to do it unless i had to but im looking for a great tune with no problems.
yeah this site help me understand the chipping thing alot better.
Old Nov 2, 2004 | 06:00 PM
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo90lude &raquo;</TD></TR><TR><TD CLASS="quote">so the obd0 is ok???? </TD></TR></TABLE>
yes, of course it is
Old Nov 21, 2004 | 01:28 AM
dwchkypmp20's Avatar
all you need to go obd1 form obd 0 is a harness jumper?
Old Nov 21, 2004 | 04:44 AM
hondaguyef's Avatar
Default Re: obd0-obd1(b18a-b18b)question?? (dwchkypmp20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwchkypmp20 &raquo;</TD></TR><TR><TD CLASS="quote">all you need to go obd1 form obd 0 is a harness jumper?</TD></TR></TABLE>
No, you'll need a 4 wire o2 sensor and an OBD1 distributor. I personally love Uberdata. I ran it when the car was NA and now that it is FI, I love UD even more . ( I can't comment on Turbo Edit cause I have never used it)
Phil
Old Nov 21, 2004 | 08:48 AM
Boosted Chemist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo90lude &raquo;</TD></TR><TR><TD CLASS="quote">so the obd0 is ok???? what about uberdata and the stock ecu. I kind of feel the same way about swaping ecu's and i didnt want to do it unless i had to but im looking for a great tune with no problems.
yeah this site help me understand the chipping thing alot better.</TD></TR></TABLE>
it all depends, obd0 and turboedit is great, i made 265 whp on it , but if u want all the bells and whistles that hondata offers i would go obd1 and get chrome or uberdata. All u need is a obd0--&gt; obd1 harness (105 blownhatch ) and the obd1 dizzy which it sounds you have. You can disable the o2 heater and retain a single wire o2 or wire up hte four wire or my personal favorite get a wideband and use the narrow band output.
all and all it depends on your goals/money
jorDAn9
Jul 15, 2008 05:29 PM
teggytegteg
Apr 16, 2006 12:11 AM
G2integra217
May 8, 2005 11:39 PM
kyden
Nov 19, 2004 10:45 PM
