Boost Lag Question
Old Nov 1, 2004 | 01:19 PM
civiceg500's Avatar
Default Boost Lag Question
What would be a better set up here? I have a DOHC ZC and want to run about 8psi on a turbo. I looking at T25, T28 and T3. All internal wastegate. What do yall think? Which one is better at this psi?
Old Nov 1, 2004 | 01:49 PM
tgreaves's Avatar
Default Re: Boost Lag Question (civiceg500)
Why do you want to run exactly 8 psi..
I would get a T3 and run what ever psi it takes to get to your reasonable hp goal as long at the T3 you get is setup for the power range your trying to achieve..
Old Nov 1, 2004 | 01:55 PM
lanojp1's Avatar
you should be more interested in what kind of horsepower you want to acheive and not how many PSI you want to run...it will make it easier to select a housing, trim, a/r, etc....
Old Nov 1, 2004 | 01:59 PM
civiceg500's Avatar
Default Re: (lanojp1)
Gottcha, well i'm going to keep the stock bottom and do a few needed spark and fuel upgrades, i'm trying to achieve about 200hp to the flywheel, would that be achieveable with a DOHC ZC
Old Nov 1, 2004 | 03:14 PM
Turbo E's Avatar
t3 sounds like the best bet.
t25 will spool mad quick, but the power may drop off before you reach your desired HP.
Cole89ef
Aug 6, 2009 07:03 AM
nstereo2002
Jan 10, 2007 07:07 PM
Del_Slowest
Oct 27, 2004 12:08 PM
boosted_zc
Jan 20, 2003 03:54 PM
ludelvr
Nov 3, 2002 11:33 AM
