> Anyone running the BLOX mani yet?
1 Post
I got one...planning to use it on my '01 GSR with SC34 and TiAL 38mm WG.
Would like to here any thoughts so far.
Any HP #s
Hows hood/valve cover clearance with a TiAL? Need an elbow?
etc
Any HP #s
etc
Re: (96GSRkId)
hopefully i should have numbers this weekend. my setup is
b16a2 stock
rc 550cc
walboro
blox manifold
precision sc34
vacuum manifold
turbo xs dual stage boost controller
tial wastegate.
ill let u guys know.
b16a2 stock
rc 550cc
walboro
blox manifold
precision sc34
vacuum manifold
tial wastegate.
Re: (VTC_CiViC)
have one in my room
hella dope manifolds for the price
they are just like the drag manifolds, but blox cleans them up and the wg spots is very nice
great buy
great buy
1 Post
Re: (Tactic$)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tactic$ »</TD></TR><TR><TD CLASS="quote">placing order today unless swayed otherwise.
would like to hear ANY reviews !!!</TD></TR></TABLE>
Order it up man. I don't see how you could possibly get a better mani for the price...hell, it comes with a lifetime warranty!
Re: > Anyone running the BLOX mani yet? (jfoster)
I just test fitted my blox manifold on my gsr integra.
You have to notch out the bottom of the flange at 3 different points, otherwise the flange will not sit flush on the exhaust ports. No biggie, but I was a bit suprised about this since you have to modify the manifold(or your block).
If you try mounting a 38mm tial wastegate without an elbow it ends up hitting the head and valve cover. I ended up grinding down a few mm off the head and valve cover where it got in the way and now it clears. Also, there were no problems clearing the hood on my integra.
I am keeping my A/C, so for my 5-bolt t3/04e turbo to clear, I had to grind down the tab below the B18C1 stamp and cut out the block webbing to the right of it. Very tight fit but it is doable.
1 Post
Re: > Anyone running the BLOX mani yet? (tilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt »</TD></TR><TR><TD CLASS="quote">I just test fitted my blox manifold on my gsr integra.
If you can post up some pics. Are you up and running yet? Just wondered if the TiAL still clears when the motor rocks?
Re: (XxRoCkMaNxNEOxX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XxRoCkMaNxNEOxX »</TD></TR><TR><TD CLASS="quote">hopefully i should have numbers this weekend. my setup is
b16a2 stock
rc 550cc
walboro
blox manifold
precision sc34
vacuum manifold
tial wastegate.
ill let u guys know.</TD></TR></TABLE>
what are you running for fuel managment? Those numbers seem a little low for a b16 with 10psi. I'm looking to hit those numbers on my LS motor if not a little more on 10psi. How do you like the blox manifold though? Got mine on my car, but have not ran it yet since I am still in the process of putting my aprts on
b16a2 stock
rc 550cc
walboro
blox manifold
precision sc34
vacuum manifold
tial wastegate.
Re: > Anyone running the BLOX mani yet? (1Bar GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Bar GSR »</TD></TR><TR><TD CLASS="quote">Any more info on this blox manifold im looking into it to just want some more reviews!</TD></TR></TABLE>
i have it on my car and it works great. holds the boost very well didnt spike on the dyno.
I have one in my room. The casting quality is great compared to the rev hard and drag manifolds. Wastegate port in the center of the runners. A great value manifold, for the price.
Can I see some pics of one of these mani's? So Blox has got to be a fairly new company right? When I first heard about it, I figured it was a cheapo company, like some eBay crap. But apparently they make pretty nice cams, intake mani's and now turbo mani's too. Interesting. What was the price?
Re: (Disco Stu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Disco Stu »</TD></TR><TR><TD CLASS="quote">Can I see some pics of one of these mani's? So Blox has got to be a fairly new company right? When I first heard about it, I figured it was a cheapo company, like some eBay crap. But apparently they make pretty nice cams, intake mani's and now turbo mani's too. Interesting. What was the price?</TD></TR></TABLE>
well im pretty sure most people on h-t took on the groupbuy which was 300 shipped to your door.
I am using a blox manifold, first it was a pain in the *** until I get some help, now I love it.
you have to shave you block to get the turbo to fit, and shave a little off your head ti fit a tial wastegate without using a elbow, the elbow I bought did do anything but face wastegate outlet on the #1 runner you cant use a dumptube with the elbow. everything work out fine.
1 Post
Re: (jfoster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudebwoy »</TD></TR><TR><TD CLASS="quote">I am using a blox manifold, first it was a pain in the *** until I get some help, now I love it.
you have to shave you block to get the turbo to fit, and shave a little off your head ti fit a tial wastegate without using a elbow, the elbow I bought did do anything but face wastegate outlet on the #1 runner you cant use a dumptube with the elbow. everything work out fine.</TD></TR></TABLE>
I shaved my block and the turbo is on. But the inlet is right against the clutch bleeder so I can' t put a filter on it
Re: (jfoster)
Majority of these short turbo manifolds like Blox, Drag, RevHard, & etc. will require you to shave the webbings off the blocks if you have the compressor facing the passenger side cause it was originally intended for A/C friendly.
Plus since most people are running huge *** turbos does not help either. I run a small T3 with a RevHard mani and it does not require any shavings of my block, it's not even close. The block was shaved before to accomadate an T3/T04b(R.I.P).
But Blox mani is good for the price, not too sure how long it will last cause it looks like the drag one and everyone knows drag manifolds crack between #3 and #2 in due time. I would like to see how it holds up.....
