UBERDATA chipping! NEED HELP!!!! PLEASE!!!
Old Oct 29, 2004 | 03:59 PM
slambedcivic's Avatar
Default UBERDATA chipping! NEED HELP!!!! PLEASE!!!
this is a P28 ecu from keebler65's writeup. Its kinda hard to see but surrounded in PINK under J1 (where the jumper is supposed to go) there is a spot for a resistor that supposed to go in. there isnt a spot for this resistor on my P75, what am i supposed to do?
Old Oct 29, 2004 | 04:10 PM
onePOINTsix's Avatar
Default Re: UBERDATA chipping! NEED HELP!!!! PLEASE!!! (slambedcivic)
put a 1-1.2K 1/8watt resistor in there
Old Oct 29, 2004 | 04:14 PM
Mad Cow's Avatar
Default Re: UBERDATA chipping! NEED HELP!!!! PLEASE!!! (onePOINTsix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Solder a 1.1K ohm resistor into R54 location marked in white lettering (not needed on P72 USDM GSR) (Note: 1K - 10K resistors seem to work ok. This is a simple pull up/pull down resistor. 1K resistors seem to work well with ROM emulators that have trouble with 10k resistors) </TD></TR></TABLE>
From http://www.ecimulti.org/uberdata/faq/index.html#1
Old Oct 29, 2004 | 04:16 PM
Syner-G-Racing LLC's Avatar
post a pic of the p75...it may be a different circuit layout. or the resistor may activate the circuit instead of the extra jumper. just post a good clear pic.
Old Oct 29, 2004 | 04:24 PM
Default Re: UBERDATA chipping! NEED HELP!!!! PLEASE!!! (Syner-G-Racing)
alright guys... im getting the pixers now!
Old Oct 29, 2004 | 04:26 PM
Old Oct 29, 2004 | 04:37 PM
Jim Truett's Avatar
The resistor is not needed on the P72 and P75. The PCB is different.
Old Oct 29, 2004 | 04:38 PM
Default Re: UBERDATA chipping! NEED HELP!!!! PLEASE!!! (Jim Truett)
so all i have to do is put that jumper in there?
Old Oct 29, 2004 | 05:01 PM
ALL GOOD NOW!! thanks people for the help! i got it running with my LS all motor chip!
Old Oct 29, 2004 | 05:14 PM
hondaguyef's Avatar
Good **** bro! Sorry I couldn't help you earlier I was busy when you called.
Phil
Old Oct 29, 2004 | 05:45 PM
Default Re: UBERDATA chipping! NEED HELP!!!! PLEASE!!! (hondaguyef)
Old Oct 29, 2004 | 06:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">Good **** bro! Sorry I couldn't help you earlier I was busy when you called.
Phil</TD></TR></TABLE>
its all good man! now all i need is an oil pan tap setup and ill be boosting
88h22_CRX
Jul 10, 2011 12:08 PM
huntarrr
May 28, 2005 03:52 PM
ferio 95
Oct 2, 2004 07:12 PM
96MidoriHatch
Sep 12, 2004 11:02 PM
dragonrcr
Nov 29, 2002 05:44 PM
