Help me identify these pistons
Help me identify these forced induction pistons
This is a B18a1 block I recently purchased from a friend. I took the head off to check the condition of the cylinder walls and need to figure out what type/compression these pistons are. Please disregard all the crud in cylinder #2 and #3, they will be clean prior to installation.
Here's a picture of the block:
Cylinder #1 piston:
Closer shot:
Side shot:
Cylinder #1 piston:
Closer shot:
Side shot:
Re: Help me identify these forced induction pistons (Ek9_Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ek9_Civic »</TD></TR><TR><TD CLASS="quote">This is a B18a1 block I recently purchased from a friend. I took the head off to check the condition of the cylinder walls and need to figure out what type/compression these pistons are. Please disregard all the crud in cylinder #2 and #3, they will be clean prior to installation.
Ask your friend ?
Ask your friend ?
Re: (Schister66)
if they are 9:1 cp pistons, then they should be paired with some aftermarket rods correct? Will removing my oil pan help me see if I have aftermarket rods and rod bolts?
InsertCleverSN
04-27-2003 06:41 PM
