EBC "Gain" knob?
EBC "Gain" ****?
I have Greddy Type-S boost controller.
The middle and right **** control "Lo" and "Hi" boost presets, while the **** on the left controls "gain." I've done some research but can't find a really good explanation on what the "gain" **** does. Turned it up on the dyno yesterday and saw more boost earlier which was good because boost was creeping to 15 later than I believe it should have. Can anyone explain to me exactly what this feature is supposed to do and how it should be used?
Re: EBC "Gain" ****? (kuja)
its the duty cycle of the solenoid, you want to have it set per the turbo, if you have a really small turbo that builds boost really fast it will have a tendency to over boost so you set the gain lower, the opposite with a larger turbo, you set the gain higher so the wastegate stays closed longer so boost is reached more quickly without overboosting
i think thats about it, if someone wants to correct me please do
Modified by Soccerking3000 at 5:12 PM 2/4/2007
Re: EBC "Gain" ****? (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">its the duty cycle of the solenoid, you want to have it set per the turbo, if you have a really small turbo that builds boost really fast it will have a tendency to over boost so you set the gain lower, the opposite with a larger turbo, you set the gain higher so the wastegate stays closed longer so boost is reached more quickly without overboosting
Modified by Soccerking3000 at 5:12 PM 2/4/2007</TD></TR></TABLE>
That makes sense. I have a precision SC61 and it was turned all the way down, haha. Turned it up a bit and definitely saw a difference.
Re: EBC "Gain" ****? (McLude2nR)
yea set it higher but you might need to lower the hi and low settings then. I also i noticed your in dayton, i go to UD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">yea set it higher but you might need to lower the hi and low settings then. I also i noticed your in dayton, i go to UD </TD></TR></TABLE>
So do I! I'm at UD Law. I graduate in May. See you around campus. I've been trying to organize a UD tuner meet with some srd members.
HybridCoupe
10-31-2002 12:47 PM
