supra help please
Old Jan 31, 2007 | 09:39 PM
LSTEG98's Avatar
Default supra help please
i no this is honda forums but its the best website for info anyways my boy has a 1987 toyota supra turbo ... the problem is when he trys to go the car turns jerks and wants to turn off on him if he goes over 3000 rpms could it b that its not getting enough fuel or what???
Modified by LSTEG98 at 10:20 AM 2/1/2007
Old Jan 31, 2007 | 10:31 PM
LSTEG98's Avatar
Default Re: supra help please (LSTEG98)
ttt
Old Feb 1, 2007 | 03:41 AM
markaria's Avatar
Although I find it hard to READ your post, I'll take a guess... perhaps the car is hitting some sort of a boost cut (overboosting), or perhaps there is a fuel pump/regulator problem?
Good luck
Old Feb 1, 2007 | 05:09 AM
DaveF's Avatar
Default Re: supra help please (markaria)
arent those cars mass air cars ? id look for vacum leaks 1st.
Old Feb 1, 2007 | 05:30 AM
KingOfQB's Avatar
or ecu went bad
Old Feb 1, 2007 | 06:07 AM
99B16Si's Avatar
pretty broad question, but id double check and make sure your not low on vtec fluid
Old Feb 1, 2007 | 06:19 AM
BoostedEG6's Avatar
Default Re: (99B16Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si &raquo;</TD></TR><TR><TD CLASS="quote">pretty broad question, but id double check and make sure your not low on vtec fluid</TD></TR></TABLE>
That would have been funny if he where talking about a Honda
But hey there is always one in the crowd
To the OP it sounds like your boy is having problems with his ECU
Old Feb 1, 2007 | 07:30 AM
99B16Si's Avatar
Default Re: (BoostedEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 &raquo;</TD></TR><TR><TD CLASS="quote">
That was the joke
either way theres really not enough information to troubleshoot this....
Old Feb 1, 2007 | 08:15 AM
White Smoke's Avatar
i my honda
Global Mod
I too thinks its MAFS related.
Old Feb 1, 2007 | 09:19 AM
LSTEG98's Avatar
yea i was readin online it they said it seems like the fuel filter is goin almost hes boostin 8 all the time so could that b a problem
Old Feb 1, 2007 | 10:16 AM
Fo-Do Fanatic's Avatar
Default Re: (LSTEG98)
when my poopra was running, the mass air flow sensor (the big hunk of plastic by the air filter) went bad. it caused it to jerk and want to die whenever i gave it more than like 25% throttle. check that and your vacume connections.
Old Feb 1, 2007 | 11:42 AM
LSTEG98's Avatar
thanks goin to try it
Old Feb 1, 2007 | 02:17 PM
fast93accord's Avatar
I have some experience with these cars... Does it only do this when trying to make boost? If so, theres probably an intake tube that came disconnected. I've seen the tube right off the turbo compressor outlet come off and we experienced the exact same thing. Car would run fine, then when you step on it it would bog out and rev down... That particular pipe even looked like it was on, but after removing the intake we found it had popped off...
Chee_dog
Oct 22, 2012 07:11 AM
type_r_teggy
Feb 14, 2008 10:47 AM
jdmb1697ek
30
Mar 14, 2005 04:17 AM
NickQ
Mar 11, 2004 11:42 AM
91hob20hb
18
Jan 28, 2004 05:28 AM
