oil leaks on the back of the compressor housing
heya guys
im having problem with the car smoking just on the start-up (https://honda-tech.com/zerothread?id=1876508)
and when i was checking for oil level and stuff under the hood, i noticed that theres quite a bit of oil leak coming out on the back of the compressor housing of the turbo
does that mean my turbo shot ??? rebuild time ?? is that the cause why my car is blowing white smoke just on the start up everytime ??
thanks
thanks
Re: (denske)
On one of my turbo's, whenever i park the car, it leaks oil out into the exhuast side, just a small amount, and some around the turbo too. On my daily driver, a tdo5h, no oil leaks at all, no burning ever, but that has a restrictor buil into the turbo. I put a restrictor on my other one, and that helped, but i still get smoke from time to time, and it still leaks out. If your not pushing oil into the intake side, its not likely your turbo seal. Might wanna take it apart and clean up the exhaust side. Make sure no oil has coked sp??? up. As there really isn't much to seal up the exhaust side, typicaly works on air pressure differentials.
TurbothisLS
12-01-2002 03:16 PM
