Boost creep from hell!!
Old Jan 31, 2007 | 10:11 AM
faSHOwidIT's Avatar
Default Boost creep from hell!!
So i was cruisin around today and decided to get on it. I did a 4th gear roll and next thing you know my boost guage goes pass 20!, i look at the peak on the boost controller it said 25lbs. I got a 14lb spring in the wastegate but on the dyno is would creep to 16lbs. So i turned the boost all the way down to zero on the boost controller and it'll creep to 17lbs. What should i check for besides leaks on the vacuum lines? Boost controller i'm using is, Blitz SBC-ID, wastegate is tial 44mm. Peakboost ramhorn manifold.
Old Jan 31, 2007 | 11:44 AM
faSHOwidIT's Avatar
Default Re: Boost creep from hell!! (faSHOwidIT)
since i lowered all the values on the boost controller and it didnt jump to 25lbs, im guessing the boost controller is at fault?
Old Jan 31, 2007 | 11:45 AM
93turbo16's Avatar
Sounds like it. Double check all of the settings and lines. It shouldn't spike that high just out of no where.
Old Jan 31, 2007 | 11:47 AM
SOHC_MShue's Avatar
i'm willing to bet the controller is hooked up wrong.
Old Jan 31, 2007 | 12:25 PM
faSHOwidIT's Avatar
Default Re: Boost creep from hell!! (SOHC_MShue)
IN is connected to vacuum log, OUT is connected to top of wastegate, side wastegate is connected to vacuum log. It worked fine on the DYNO. but all of a sudden this happens?
Old Jan 31, 2007 | 03:51 PM
faSHOwidIT's Avatar
ttt
faSHOwidIT
Jan 31, 2007 03:59 PM
playahwitgame
Sep 19, 2006 09:08 AM
Mad Cow
Feb 24, 2005 06:12 AM
GDM Z28
Nov 30, 2003 06:13 AM
