Plugs are white but AFR Reads 11:1
I'm running a B16a (All Stock) with T3 60 Trim Turbo, Tuning with a PLM and the AFR Reads 11:1, when at WOT I shut down the engine, put the gear to neutral and check the plugs, it is white, but I don't see any speckles in it.
The plugs are brand new NGK 8's
Should this be good?
I don't hear any detonation or see any sign on the plugs.
I tried tuning on 10:1 AFR, the plugs went a little brown. Car runs sluggish.
Re: Plugs are white but AFR Reads 11:1 (Sunlight)
if the plugs are brand new like you say you might have to drive on them a while before the change colour.
