Adjustable FPR Needed?
Old Feb 4, 2007 | 07:40 PM
GSROWNSU's Avatar
Default Adjustable FPR Needed?
My fuel setup so far is as follows....
RC 550cc injectors..
walbro fuel pump..
hondata s200..
I will be running a stock gsr (rebuild) on 7-8 psi of boost...is an adjustable fpr needed to lower the duty cycle for these 550 cc injectors for 7psi or will i be ok without it...be honest i don't want to cut corners and if i need one for a good tune i will spend the extra money...i have just seen some setups without an adjustable regulator.
Thanks,
Dan
Old Feb 4, 2007 | 08:50 PM
sneakypete's Avatar
Default Re: Adjustable FPR Needed? (GSROWNSU)
You will be fine with a stock fpr.
Old Feb 4, 2007 | 09:06 PM
GSROWNSU's Avatar
Default Re: Adjustable FPR Needed? (sneakypete)
will having an adjustable fpr make it easier to tune for my setup or is it just not needed because i have big enough injectors to keep the duty cycle low enough already? I just want to make sure everything will be ok if i truly don't need one.
Old Feb 4, 2007 | 09:17 PM
LSVTECTURBO-EG's Avatar
7 or 8 lbs on 550's you'll be fine with the stock fpr.
golf-mk3
Oct 7, 2010 05:27 AM
boostin92hatch
Sep 21, 2006 05:19 AM
GT-KiLLa
Mar 2, 2004 09:53 PM
CaptainMorgan
Dec 25, 2003 09:51 PM
Precision DC4
Oct 31, 2002 04:38 AM
