motor mount brand advice
should i get energy polyurethane motor mount inserts
http://www.amazon.com/exec/obi...nosim
or
prothane motor mount inserts.
http://www.prostreetonline.com/sku/8-1904.html
i am about to purchase so please help me out. i have a 406 whp car and my motor is almost ripping out of my stock mounts. i want something to hold really strong without to much vibration if all possible.
or
Re: motor mount brand advice (Speed Infliction)
i would imagine that the inserts would be a temp solution, i would think that car/power needs whole aftermarket mounts.
Re: motor mount brand advice (93supercoupe)
i don't think so. they all have the same internals. i am not trying to spend 400 bux on some hasports when i can get the inserts to do the same thing. thanks for the reply though. anybody else.
Either one will work fine.I helped my friend install a set of energy mount inserts i believe. For the driverside mount it had 2 different pucks, a street one and a race.We went with the race insert.Worked well, had a LOT of vibration at idle. But me, i went the cheap way, i filled my mounts with 3m window weld which is just polyurethane.It also worked well but not as much vibration.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe »</TD></TR><TR><TD CLASS="quote">i would imagine that the inserts would be a temp solution, i would think that car/power needs whole aftermarket mounts.</TD></TR></TABLE>
x2.... look into innovative mounts....
http://www.innovativemounts.com/
TypeRod
12-07-2011 02:45 PM
SOHC_Brian
08-11-2004 11:30 AM
