what spark plugs you guys run on turbo setup
Old 01-31-2007, 10:27 AM
* B A N N E D *
Pnoyej6's Avatar
Default what spark plugs you guys run on turbo setup
im currently running ngk 9's and they foul out last night at the dyno. Will ngk densor 7's work?? Whats best for 7psi
Old 01-31-2007, 11:10 AM
bigdgsr's Avatar
Default Re: what spark plugs you guys run on turbo setup (PnoyEj6)
You need to run 7's. I run the NGK R5671A-7's in my GSR at 16.5 PSI without a problem. At 7 PSI you definitely do not need 9's yet.
Old 01-31-2007, 11:13 AM
slowhonduh93's Avatar
get some NGK bkr7e.. that's what I use on my b16 turbo
Old 01-31-2007, 11:14 AM
* B A N N E D *
Pnoyej6's Avatar
Default Re: what spark plugs you guys run on turbo setup (bigdgsr)
iridium???or denso
Old 01-31-2007, 11:20 AM
jdmsiR20's Avatar
everybody is gonna suggest the NGK's...
i use one step colder denso's, just cause its what was in stock. not the iridiums either
Old 01-31-2007, 11:22 AM
A.E Motoring's Avatar
Default Re: what spark plugs you guys run on turbo setup (jdmsiR20)
i use 8s ngk
Old 01-31-2007, 11:25 AM
boostincoupe's Avatar
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: what spark plugs you guys run on turbo setup (Dual Cam Racing)
Cheap $2/plug NGK BCPR7ES's, all day every day for me
Old 01-31-2007, 11:39 AM
morgan@synapse motorsport's Avatar
Default Re: what spark plugs you guys run on turbo setup (boostincoupe)
i run denso iridium ik27's on race gas, and k22pr-u11's on pump. i only run these because the caps are removable for the honda coil sticks, but they work great, sucks that they are hard to get a hold of though.
Old 01-31-2007, 11:41 AM
riceball777's Avatar
you need ngk bkr7e
Old 01-31-2007, 12:21 PM
B18Sleeper's Avatar
Default Re: (slowhonduh93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowhonduh93 &raquo;</TD></TR><TR><TD CLASS="quote">get some NGK bkr7e.. that's what I use on my b16 turbo</TD></TR></TABLE>
x2 what i am going with
Old 01-31-2007, 02:20 PM
ccivic's Avatar
Default Re: (B18Sleeper)
Never had a problem with BKR7E's. You can get them from NAPA and Advance for less than $2/plug.
Old 02-01-2007, 08:29 AM
rocket256's Avatar
Default Re: what spark plugs you guys run on turbo setup (PnoyLSV-T)
I used BKR7EIX-11 in my setup.
Old 02-01-2007, 12:35 PM
highmilehatch's Avatar
Default Re: what spark plugs you guys run on turbo setup (rocket256)
NGK BKR7E, part number 6097.
Old 02-01-2007, 04:39 PM
dizzyek's Avatar
Default Re: what spark plugs you guys run on turbo setup (highmilehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highmilehatch &raquo;</TD></TR><TR><TD CLASS="quote">NGK BKR7E, part number 6097.</TD></TR></TABLE>
x2
Old 02-01-2007, 05:14 PM
* B A N N E D *
Pnoyej6's Avatar
Default Re: what spark plugs you guys run on turbo setup (dizzyek)
my ek hatch bogs a little now , is it because the black plugs
Old 02-01-2007, 05:58 PM
nihad's Avatar
ngk r
Old 02-01-2007, 06:02 PM
* B A N N E D *
Pnoyej6's Avatar
Default Re: (nihad)
is bad to run a black spark plugs. WE checked plugs on dyno and its black on the tip
Old 02-01-2007, 07:48 PM
B18Sleeper's Avatar
Default Re: (PnoyLSV-T)
i dont see that as good but i dont see it so bad that it will hurt to much...but i say u need to change them soon.
Sohc Turbo
11-02-2007 07:34 AM
staticchmbr
01-14-2006 07:29 AM
patdemps
05-25-2004 06:08 AM
MrCrx
04-30-2004 11:53 AM
blackccoupe
03-31-2004 02:50 PM
Quick Reply: what spark plugs you guys run on turbo setup
