will a b16 handle a t20
Old Feb 5, 2007 | 05:27 PM
joethejoeman's Avatar
Default will a b16 handle a t20
Like what it says, i have a B16 stock. I plan on going turbo, i was planning on using a t3/4. I got a really good deal on a garrett t20 turbo rebuilt and i was wondering if i should take advantage of the offer, or get a t3/4. Will a stock b16 be able to handle a t20??
Old Feb 5, 2007 | 05:48 PM
civicjdmb16a's Avatar
Default Re: will a b16 handle a t20 (joethejoeman)
you bet
Old Feb 5, 2007 | 06:18 PM
Dunc's Avatar
BCICAN
T20?? As in smaller than a T25? Umm yea, the B16 will have no problems at all but are you really sure you want to use that small of a turbo? I'd find it hard to believe that it would be efficient at ~8000rpm and I find it even harder to believe that it will give any worth while added whp.
Old Feb 5, 2007 | 06:33 PM
93supercoupe's Avatar
Default Re: will a b16 handle a t20 (Dunc)
it would be more work to find a mani with the right flange than its worth.
GT35R FTW!!!!!!!!!!j/k
Old Feb 5, 2007 | 08:00 PM
HiProfile's Avatar
Default Re: will a b16 handle a t20 (93supercoupe)
They say ~15% less power from a T20 than a T25. I'll let you think about this rhetorical question: What does 15% less from not enough get you??
My guess is you'd make no more power with a T20 on a stock b16 than you would from an NA b16 with itr cams. You'd get serious low-mid range with the T20, but you'd need an LS trans to get any traction. It would probably be able to spin the tires early, but hook back up as it falls on its face when vtec hits.
BTW T20 uses the common T2 flange (T20/T25/T28), or at least the off the shelf version does. Greddy/HKS manis use that flange.
Old Feb 5, 2007 | 10:38 PM
SOHC_MShue's Avatar
that turbo will be a waste of time on a b16
Old Feb 6, 2007 | 02:43 AM
Default Re: will a b16 handle a t20 (SOHC_MShue)
ok, I thought a t20 was bigger than t3/4. So I should ditch the whole t20 idea and go t3/4? Im looking for mid and Top end power. What turbo would be satisfactory for me in this case?
Old Feb 6, 2007 | 04:04 AM
30 or 35R
Old Feb 6, 2007 | 12:48 PM
Precision SC32 Turbo - 480 hp
That would be fine
Old Feb 6, 2007 | 02:31 PM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">30 or 35R </TD></TR></TABLE>
There is no reason to spend that much money on either of those turbos on a stock block B16....you would never reach the efficiency range of the turbo. You would be just fine w/ a standard T3/T04 or a standard bearing GT series...i'm using the latter on my stock GSR
Old Feb 6, 2007 | 03:35 PM
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">
There is no reason to spend that much money on either of those turbos on a stock block B16....you would never reach the efficiency range of the turbo. You would be just fine w/ a standard T3/T04 or a standard bearing GT series...i'm using the latter on my stock GSR</TD></TR></TABLE>
exactly my point
Old Feb 6, 2007 | 04:20 PM
Default Re: (civicjdmb16a)
The manifold, i was talking to a shop and they were telling me about 700 dallors for a hand made ram style mani. I no that ebay ram mani is junk. What if i can get hold of cast manifold would that work? I havent got many opinons on that yet.
Old Feb 6, 2007 | 04:37 PM
Default Re: (joethejoeman)
cast would work fine. i wouldnt go to high w/boost though. you can get a SS log.
i got my ramhorn from this guy. my brother has his log on his ZC and he loves it Check my build to see it
http://www.pfabrications.com/inc/sdetail/296
kte324
Mar 26, 2009 05:25 PM
GetawayInMoscow
Mar 4, 2007 11:56 AM
alex288
Apr 28, 2006 12:50 PM
twisted_jdm_b16
Jan 13, 2006 01:02 PM
Tex Blackwell
Jul 30, 2004 06:01 AM
