boost controller for supercharger???
Old Feb 5, 2007 | 11:51 AM
civickiller's Avatar
Default boost controller for supercharger???
i know that the pulley size determines boost psi but is there any way to lower your boost without resorting to a bigger pulley?
my friend, pretty good fab guy, fabricated his own custom mounts or bracket to mount a supercharger from one of those superchared t birds. it mounts in the front in front of the header bolted to the block running off the crank pulley i believe. anyways
his car is boosting like 22psi or something like that. he wanted to know if theres like a device that can bled off excess boost. kinda like a wastegate to bleed off exhaust to lower boost, something like that but for a suoercharger??
Old Feb 5, 2007 | 12:02 PM
99B16Si's Avatar
blow off valve i believe can do this, i forgot how they have to be setup tho. kinda acts like a wastegate, but in the intake track instead of the exhaust
Old Feb 5, 2007 | 12:33 PM
STREETWERKZ's Avatar
Default Re: (99B16Si)
if he set the car up to 22 psi with pullies.... yes, he can lower the boost levels with a boost controller.
but if you are at 15 psi, you can not RAISE boost levels to 20 psi using a boost controller. unless he has the 20 psi pulley system in place, and lowered boost.
does that make sense?
ask how to make on in this thread..... i believe RmcDaniels made a boost controller for a supercharged honda.
https://honda-tech.com/zerothread?id=1214810
Old Feb 6, 2007 | 06:58 AM
rmcdaniels's Avatar
Default Re: boost controller for supercharger??? (civickiller)
How did he get around the T-bird M90 blower being a CW blower on a CCW Honda motor?
Old Feb 6, 2007 | 07:29 AM
Default Re: boost controller for supercharger??? (rmcdaniels)
that's what i thought too, but i then remember you posting a ccw kit. so i figured thats what he used and didnt want to question it.
Old Feb 6, 2007 | 06:09 PM
Default Re: boost controller for supercharger??? (STREETWERKZ)
he didnt do anything or use a kit, the supercharger spins ccw
Spaceballsthelunchbox
Sep 4, 2010 02:52 PM
ochsy03
Mar 24, 2005 08:53 AM
dallasyoung
Feb 3, 2003 04:56 PM
Snafu-Si
Mar 5, 2002 02:07 AM
Cyrio
Dec 4, 2001 07:00 PM
