manual timing? "tuning"
I found a part that would allow me to set timing in (+-)1 deg increments from stock. could something like that be used for tuning or would i still need to go with fill engine management?
Re: manual timing? "tuning" (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">Full EMS ftw.
msd btm </TD></TR></TABLE>
Its not MSD but it is on a bike. the part is made by factory Pro
"This is the patented Factory Pro Adjusted Ignition rotor.
Patented for it's absolute 1 degree indexing ability - without trying to read inaccurate "hash" marks like other adjustable advancers AND the unique internal adj. screw - there are NO exposed screws to loosen and fall out inside the engine like ALL other adjustable ignition rotors!
(We aren't falling for the other adj. ign. rotor manufacturer's "Loc-Tite the adjustment screws so they don't fall out..." suggestion!"
Re: (93turbo16)
im not 100% sure on bikes timing setup, but i do know there isnt a diostro.
And for a bike that isnt turbo, i would say this and a commander would be all u need to get the max power out of ur bolt on upgrades.
Not a band aid.
Not a band aid.
Re: (93supercoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe »</TD></TR><TR><TD CLASS="quote">im not 100% sure on bikes timing setup, but i do know there isnt a diostro.
Not a band aid.</TD></TR></TABLE>
EDIT. I am retarded.
But I would still say a power comander (?) or something similar for tuning. The shop I use just got a bike dyno, so this is something i am just starting to get into but am less than knowledgable in.
Modified by 93turbo16 at 4:05 PM 2/2/2007
Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">
Modified by 93turbo16 at 4:05 PM 2/2/2007</TD></TR></TABLE>
OK so here it is, the bike is a 2003 CB919 its got a 10.8:1 CR which is kinda low for a street bike. I dont know how many of you remember the 900RR, this is the same engine from that bike but with a lower compression. Also, the 919 now has fuel injection and smaller cams which make it a bottom end beast.
A power commander is basically a SAFC that is tuned via USB port.
Re: (85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 85 »</TD></TR><TR><TD CLASS="quote">
I have that on my rc51
Re: (PrecisionH23a)
:::BUMP:::
So you guys think it would workout ok? how much does the timing get retarded in a tune? if this part allows me to go up to 10 deg would that be enough?
Re: (85)
Rule of thumb .75 degree's per psi of boost. Fuel uses, bore size, etc all plays a factor though.
No, don't run that unit. On obd1 distributor's you can already adv/ret your base timing.
Re: (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">Rule of thumb .75 degree's per psi of boost. Fuel uses, bore size, etc all plays a factor though.
No, don't run that unit. On obd1 distributor's you can already adv/ret your base timing.</TD></TR></TABLE>
Ok, so what would be a good ECU to use? I am using individual throttle bodies and it is on a bike.
Re: manual timing? "tuning" (85)
Well if this is for a bike and there is no question about FI, why is it in the FI section? I'd imagine you'd get more experienced opinions about this over there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">I thought the pc3r had ignition control as well?</TD></TR></TABLE>
there is an extra box you can hook up that will let you do it but as far as i know they dont make it for my bike. at least not yet...
