shitty luck leads to this headgasket question
ok guys please dont tell me to search i just spent the last half hour doing it and couldnt find what i wanted to know if yall can find it ur bad *** props from me lol ok well heres my thing i got a 81.5 mm comectic head gasket .074" for my b16 i was planning on building for boost well i threw a rod in my damn block today and have a spare ls block laying around and a lsvtec conversion kit also from a past motor and my pistons, havent ordered the rods yet my questions is ... will this headgasket work on a lsvtec everything i found just said they reccomend a ls gasket didnt say not to use the vtec one any help would be apreciated thanks in advance and also i have the stepped dowels and also have stock dowels dont know if that would make a diffrence
Re: shitty luck leads to this headgasket question (civicgeek133)
You need the LS gasket. Get OEM honda gasket. B16 gasket will leak. If your going ls/vtec, you will need the stepped dowels.
Re: shitty luck leads to this headgasket question (ek99)
well iam running oversized pistons there 81.5 mm so i cant run oem gasket i just payed 116 for the cometic sucks i cant use it
Re: shitty luck leads to this headgasket question (dpetro1)
ok since i cant use it does anyone want to buy a cometic low compression head gasket for a B16 lol sucks i tore my b16 block up and have to go ls now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek99 »</TD></TR><TR><TD CLASS="quote">You need the LS gasket. Get OEM honda gasket. B16 gasket will leak. If your going ls/vtec, you will need the stepped dowels.</TD></TR></TABLE>
False. Golden eagle sell their ls/vtec conversion kits with OEM b16 headgaskets. Also, i'm using an OEM b16 headgasket on my 81.5mm lsvtec currently.
The ls headgasket fits the block perfectly, the b16 gasket fits the head perfectly. Comparing both to head and block, I feel the b16 gasket is the better choice. You can get the b16 gasket cheaper from honda aswell.
However, an ls headgasket also works, thats what I was using before the teardown.
civicgeek133
02-03-2007 03:07 PM
