bored d16 ok??
ok, i'm building up a d16z6 i got for boost... planing on running about 14lbs.. any ways i think its going to need to be bored do to some rust on the cylinder walls... will this make the cylinders to weak for tha kind of boost? if so what is the cheapest and were could i get some sleeves for it??
thanks, sean
thanks, sean
For the most part if the block has already been bored once and there is sufface rust on the cylinder walls you could either have the block honed, or simply spray down a rag with WD-40 and clean the rust off. If you are planning on building the block though i would have the block bored/honed incase. Stock sleeves should not be bored past .50mm over stock.
As far as getting the motor resleeved check out the FI marketplace section, there is usually deals around $800+.
Most D16's [that I've seen] require to be bored out +.5mm (aftermarket pistons aren't availible +.25mm). You need to have an automotive machine shop check the block. If its w/in factory tolerances, a light hone is all it needs. Not only for removing rust, but to deglaze the cylinders for the new rings. Otherwise a .5mm increase won't hurt the sleeves strength, unless you mean 14psi from a gt42.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IA95civicDX »</TD></TR><TR><TD CLASS="quote">thanks guys, any one no were to get over size vitara pistons?</TD></TR></TABLE>
PM fjt, that's who I got mine from & they arrived rather quickly.
guy_from_nerk
Jul 28, 2013 12:25 PM
