help car hesitates after 5000 rpm
hey guys got a turbo d16y7 and recently it has been hesitating real bad and sometimes wont go past 5000 rpm what could cause this bad dist maybe?, not burning oil or collant i dont think so at least any help is appreciated thanks
Re: help car hesitates after 5000 rpm (blackccoupe)
See if you have fouled plugs at all, it sounds like your ingition is breaking up in the higher rpms. If plugs look good then I would test your dizzy. If you are not capable of testing the dizzy then I would just suggest swapping out a know good one of a donor car and see if it takes care of your issues.
tried a new distibutor still does it it like real choppy past 5000 doesnt want to pull but pulls hard till then ,maybe head gasket , head lifting this is a d series, i dont think it is maxing out the fuel cause it was fine til a lil while ago
gonan get arp head studs and do u think this gasket will work good
http://cgi.ebay.com/ebaymotors...QrdZ1
I would go with nothing but OEM gasket...ARP studs are great...but I dont think your problem lies in the head lifting.
Well since your running a base map...do you have a wideband? Do you know where you are as far as AFR goes? Check fuel preasure if you can. The d16y7 is at peak VE around 4600-5000 stock and im sure on the t25 you are fully spooled by this rpm so if the car has tuning issues this will definately be the problem area. When a motor reaches peak VE it demands fuel and is touchy with ign timing. Was the car running good untill the colder months? If you want, e-mail me your bin so i can get an idea of where your at.
the car smokes a desc amount for a while now plugs are normal color no oil consimption and the rad was a tad low the other day could the head be lifting maybe causign it to cut out?
Re: help car hesitates after 5000 rpm (turbomoe)
you said you're on a basemap...
has it always done this or is it new?
Alot of basemaps are made with a fuel cut out at a certain psi , maybe this is your problem
